Clutch is slipping! Need a shop in Denver.
I blew an HPOP O-ring on my way across Kansas, lost about 2 gallons of oil before I made it to a repair shop. Got the leak fixed. My clutch is slipping on the stock tune in 5th gear anytime I give it boost at highway speeds. It has less than 10k miles.
I'm struggling to find a shop in Denver that is willing to do the drain modification. Everyone says "just fix the leak" ... I have fixed the leak, and I fix other leaks anytime they come up... the problem is that leaks happen more often than not on this dumb rig... and by the time a leak is discovered, the flywheel is already soaked.
I want to add the copper tubing so this isn't an issue again. Can anyone recommend a shop in Denver that will do this?
I also want to kick the crap out of the engineer who put the valley drain above the flywheel. Does anyone have his address?
That is a thought. I have read accounts of folks fixing this with brake cleaner but I see no way to get at it without pulling the trans. At that point.. might as well put in a new one. I also called South Bend and they said it likely wouldn't work on the organic disc but WOULD likely work on the ceramic one. Mine is organic, unfortunately.
I also considered drilling a hole at the bottom of my transmission's bell housing and trying to spray from there while someone holds the clutch in and bumps the starter. Seems ghetto but this likely isn't the last time it will happen since these trucks leak so much... I can always put a rubber plug in the hole.
They’re not in Denver but if you look at their reviews they do excellent work. Give them a call ask for Jesse.
I used Supertech Engine Degreaser when my HPX fitting leaked everywhere. The stuff foams up really well and the head looked brand new when I rinsed it off.
https://www.google.com/search?q=Best...#istate=kp:xpd
53fordman1
08-30-2018 12:44 PM
carlsson
10-08-2009 09:46 AM
Trigger_17
01-27-2004 09:14 PM
