Bronco II Ford Bronco II
Bronco 2 stalling
Old Sep 22, 2003 | 02:09 PM
subiad's Avatar
subiad
Talking Bronco 2 stalling
I have a 1986 Bronco2 that is stalling when slowing down to stop.
This occurs between 2nd and 1st gears. I've recently replaced the dcap, plug wires, power brake booster and the TPS. I've checked to make sure that there ar not any vaccuum leaks. I'm wondering If I missed one. Any ideas?
Dave
Old Sep 22, 2003 | 02:14 PM
Big Orn's Avatar
Big Orn
Bronco 2 stalling
Welcome to FTE, subiad. Go here
https://www.ford-trucks.com/forums/f...php?forumid=44
to get your answers for your Bronco. It's down the page a little further. There's folks there that can help you.
Old Sep 22, 2003 | 02:19 PM
Big Orn's Avatar
Big Orn
Bronco 2 stalling
Hah!! Forget the link, subiad!! It was already moved! Sorry about that!
Old Sep 22, 2003 | 05:49 PM
mrshorty's Avatar
mrshorty
Bronco 2 stalling
Does it stall while slowing down if you put the transmission in N while slowing down? When you say it occurs between 2nd and 1st, what, specifically, is happening?
Old Sep 22, 2003 | 05:57 PM
subiad's Avatar
subiad
Bronco 2 stalling
It stalls while slowing down between 2nd and first
Old Sep 22, 2003 | 05:58 PM
subiad's Avatar
subiad
Bronco 2 stalling
engine quits and needs to be restarted. It happened twice this morning. I have driven several times since then and it did'nt stall while stopping.
Old Sep 22, 2003 | 08:47 PM
lewie's Avatar
lewie
Bronco 2 stalling
Had the same problem with my 85 bronco. Set the idle up a touch and I have not ever had to restart at a stop sign since.
Old Sep 22, 2003 | 08:53 PM
Ken00's Avatar
Ken00
Bronco 2 stalling
Clean or replace the IAC, this controls the idle speed, adjusting the throttle plate is not the correct way to fix the problem.
Old Sep 23, 2003 | 10:22 AM
subiad's Avatar
subiad
Bronco 2 stalling
What's the IAC?
DAS
Old Sep 23, 2003 | 10:57 AM
Ken00's Avatar
Ken00
Bronco 2 stalling
Idle air control valve, looks like a silver film canister with a tail and two wires located on the upper passengers side intake have way back.
Pkupman82
Jan 29, 2017 08:30 AM
Hummer_Hogs
Bronco II
Jan 10, 2017 02:30 AM
willisde
27
Jan 14, 2016 01:27 PM
Encho
Mar 25, 2011 01:07 PM
fnx4wheeler
Dec 25, 2010 11:10 PM
