trans
Old Jul 16, 2018 | 07:50 PM
mx80boy's Avatar
mx80boy
trans
i have a 94 f150 xl single cab with a 300 i6 and e4od transmission. While driving and at speeds over 40 mph it will drop all gears and act as if i threw it into neutral and after rolling a while it will catch back and continue pulling. i have dropped the transmission down into second when this has happened and i have second gear no question. its just 3rd gear and overdrive
Old Jul 18, 2018 | 11:22 PM
jk080's Avatar
jk080
Transmission Rebuilder
Could be something simple like a failing range sensor, just needs to be checked out with a scan tool that can monitor the sensors and computer commands.
Old Jul 19, 2018 | 07:22 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
On a pre-1995 model there is a 99.9% chance that it is a failing range sensor. If it isn't brand new I recommend replacing it with or without data to support the change.
autotech2
25
Oct 16, 2011 12:37 PM
bradleygt302
Mar 8, 2004 06:29 PM
VanMan58
May 23, 2003 06:43 PM
jethro
Sep 23, 2001 05:43 PM
billyb
Jul 17, 2001 01:43 PM
