E150 to E350 frame comparison
Old Jul 16, 2018 | 02:05 PM
breken5096's Avatar
breken5096
Does anyone know if the frames are the same between the two models? It seems that the quick checks I have made (just using a tape measure without crawling underneath) that they may be the same frame. Once I get a chance I intend to put each on the lift to closely check resemblance but thought I would ask here first in case someone already has the answer.
It's me again....trying to decide if I can convert my E150 conversion van to a camper hauler. I'm sourcing additional donor vans right now. Specifically looking for a V10, 4R100, 12 passenger, 4.30 gear rear end donor van to just put he conversion van body on.
Old Jul 18, 2018 | 10:28 AM
Teutonics's Avatar
Teutonics
It may vary by year (I don't know), but I do know that on 2006 model the E350 has a heavier duty frame. There is a technical specification document somewhere out there (I downloaded from somewhere years ago) that gives exact dimensions of the two different frames.
From the document ("e-seriesvan_06-ms.pdf", no title page for reference)
FRAME SPECIFICATIONS
Model/Series - Wheelbase (in.) - Maximum Side Rail Section (in.) - Section Modulus (in.) - Yield Strength (psi)
E-150 ------------138 ----------------- 6.05 x 3.18 x 0.161 ------------------ 2.92 ----------------------- 36,000
E-250 ----------- 138 ----------------- 6.16 x 3.18 x 0.181 ------------------ 3.30 ----------------------- 36,000
E-350 ----------- 138 ----------------- 7.69 x 3.18 x 0.212 ------------------ 5.44 ----------------------- 36,000
Edit - sorry the spacing/tabs doesn't come through... I added dashes to separate content.
Old Jul 18, 2018 | 11:13 AM
pbeggs's Avatar
pbeggs
seems to be same basic dim. just thicker steel as you go from 150 to 350 looking at the specs for 2010
Old Jul 18, 2018 | 09:20 PM
wirelessengineer's Avatar
wirelessengineer
Hmmm. I did a bit of searching and found various claims that the frames are all the same, but nothing to back that up. It doesn't make any sense to me that the difference between a 1 ton and a half ton is ONLY the springs, or only the springs and axles. A heavier duty vehicle should have a heavier frame.
Nice to see some documentation of what just ought to be common sense.
Old Jul 19, 2018 | 03:55 AM
pbeggs's Avatar
pbeggs
150 frame 46720 pounds (yield strength what it would take to pull the frame apart)
250 frame 52800
350 frame 87040
that being said the only difference in size would be the thickness of the steel used for the frame rails,.. body should be interchangeable
width of frame rails is the same,.. the heavier get slightly taller and thicker
thunderbolt427
24
Dec 24, 2019 07:08 PM
tacobronco
May 11, 2009 07:43 AM
wickedgood
Apr 21, 2007 04:57 PM
ACESN8S
Mar 15, 2005 03:33 AM
