Ford Van frame dimensions
Old Oct 8, 2012 | 01:47 PM
thunderbolt427's Avatar
thunderbolt427
I am looking for a suitable frame to use to build a 42 Ford coe pick up. Was told to check into van frames as the steering box is in the proper location. But no one seems to know what year van to use. Does anyone know of a site that will show frame widths and dimensions for all years? TIA
Old Oct 8, 2012 | 10:07 PM
IDIDieselJohn's Avatar
IDIDieselJohn
What dimensions do you need exactly?
I can measure my frame, and it's gonna be the exact same measurements for all vans 1975-2012.
Old Oct 9, 2012 | 12:34 AM
thunderbolt427
Basically I just need to know how wide it is at the back of the front door. That and if it is basically straight or if it has a rise in it, or gets wider anywhere. Don't get in a hurry for this, take your time. This is just for a future build, trying to plan in advance. Appreciate the help. I just read that the van uses the same frame as the f series truck, if that is true I can just measure my truck. Thanks for the offer.
Old Oct 9, 2012 | 01:06 AM
joshofalltrades's Avatar
joshofalltrades
last i checked, vans and pickups had different frames, so i'm not sure where you read they were the same. i know for a fact that they're a different width at the rear, as hitch recievers aren't interchangable between pickups and vans. also, the vans have the front wheels farther forward than the pickups do when you compare their position against the bumper.
i would suggest you bring a tape measure next time you find yourself at the local junkyard and spend some time under one - i learn a lot that way!
Old Oct 9, 2012 | 08:28 AM
95e150CW's Avatar
95e150CW
2010 E250/E350. Most vans should be quite similar.
Old Oct 9, 2012 | 11:33 AM
thunderbolt427
Thanks 95, that gets me what I need.
Old Mar 5, 2015 | 08:30 PM
rebar13's Avatar
rebar13
Is that a fact?
Because I'm wondering if a old 78 quadvan TTB suspension could be transplanted onto my 95 E350?
Old Mar 5, 2015 | 10:29 PM
vettex2's Avatar
vettex2
why not go to a junkyard to measure what you want ?
Old Mar 6, 2015 | 12:46 AM
68Mercury250Ranger's Avatar
68Mercury250Ranger
Well now its got me thinking of a 75-91Eseries body swap onto a 2003 E350 chassis. I have a very solid 79 E250 body and I drive a 2003 E350 diesel, the 2003's body is toast! really shouldn't be on the road without some major work. chassis is perfect and well maintained. I have 1 2003 parts van and 1 1976 parts van. when they get cut up in the spring I might try and do some swap work..............................
Old Mar 6, 2015 | 06:50 AM
rebar13's Avatar
rebar13
Please let us know how that turned out..
I figured mine would run another half a million miles, but the body wont.
Old Mar 6, 2015 | 12:02 PM
68Mercury250Ranger
mine has 470,000km around 300,000 miles and runs as good or better than when I got it 3 yrs ago at 360,000 km. I push it like its stolen empty but when my trailer is on behind I look after it! no reason why the driveline couldn't do it all over again
Old Mar 6, 2015 | 02:30 PM
Skip1970's Avatar
Skip1970
Anyone know if they share same body mount bushings and bolts between van and pickup
Old Mar 6, 2015 | 02:38 PM
rebar13's Avatar
rebar13
No.
Truck frames are narrower and not as flat. Totally different..
Old Mar 6, 2015 | 02:57 PM
Skip1970's Avatar
Skip1970
What's that have to do with rubber bushings?
Old Mar 6, 2015 | 04:07 PM
rebar13's Avatar
rebar13
Sorry, I miss understood the question.
