heat core
Old Jul 15, 2018 | 01:36 PM
hjfomoco's Avatar
hjfomoco
heat core
how do you remove heat core with air from 78 f-100
Old Jul 15, 2018 | 10:38 PM
1TonBasecamp's Avatar
1TonBasecamp
Now that's a loaded question for our trucks!
In my case, I pulled the engine and gave it a full rebuild just because I had to remove a leaking heater core and figured I'd do them both.
So I'm not much help if you don't want to remove the engine to make it easier. Luckily, it can be done without it.
I think there are some threads here with pictures and full details on the little tips n tricks for making it easier. I'm not sure where the are so can't give a link, but I'm sure someone will.
Good luck. I'm interested in reading about it again too.
Paul
Old Jul 16, 2018 | 07:47 AM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
With or without a/c? GIANT black box in engine compartment on the passenger side ='s a/c? If you do not have a/c...look up under the dash behind the glove box. See that black box (L/H diagram), that has to come out and be opened up to access the heater core. With a/c same thing just a giant PITA IMO. Once you tell us with or without a/c the answers will roll in.
https://www.ford-trucks.com/forums/1...otor-hack.html
https://www.ford-trucks.com/forums/1...wer-motor.html
http://www.rowand.net/Shop/Cars/1979FordF100/AC.htm
http://www.ncspecialties.com/shop/heater/index.htm
Old Jul 16, 2018 | 02:29 PM
1TonBasecamp
He mentioned "with air" in the first post. Assuming he was referring to that.
Paul
Old Jul 16, 2018 | 02:43 PM
77&79F250's Avatar
77&79F250
My speed reading and comprehension do not match. The 1st link I posted is the eng compartment hack way, but the easy way.
VanGuySteve
Apr 15, 2018 03:13 PM
TOPHER1978F150
18
Oct 7, 2012 08:16 PM
Flashgordon_nz
Aug 1, 2011 04:40 AM
Travismcd
Feb 10, 2007 10:42 PM
Hammerhead
Aerostar
Dec 10, 2003 04:54 PM
