Replacing the heater core ??
Old Dec 8, 2010 | 11:05 PM
TOPHER1978F150's Avatar
TOPHER1978F150
How difficult and time consuming is replacing the heater core in a 1978 f-150 without air? I know the dash has to come out. I've done them in 4I Fox mustangs with air and it's like a 5-6 hour process, even more in an Aero. The easiest one has got to be a 4I fox w/o air, about 10 min.
It's getting cold driving the Dent in 10-15 degree weather with the heater bypassed!
Old Dec 8, 2010 | 11:47 PM
droppedf100's Avatar
droppedf100
Without a/c is easy. There are 3 bolts that hold the box in through the firewall and the vent should come off the box to make it easier. An hour or 2 at most if you take your time and clean it out. Dash does not need to be removed.
Old Dec 9, 2010 | 04:44 AM
dave_dj1's Avatar
dave_dj1
you don't have to pull any dash apart! Just as posted above, 3 nuts on the firewall, I remove the 6 or so little phillips screws and take the vent door off first (makes it easier) A word of caution when putting it all back together, 1) don't forget to hook up the control cables
2) use caution pushing the heater core tubes through the firewall being careful not to bend them.
I actualy took the glovebox (cardboard) out to make my life easier.
Old Dec 9, 2010 | 10:00 AM
jasonnerothin's Avatar
jasonnerothin
On a closely related topic, my core works great making me warm, but is intermittently very noisy doing it. I heard that if you whack it with a hammer, it fixes it.
Anyone ever performed this procedure? I'm guessing you go at it from the engine compartment with a nice soft mallet...
Old Dec 9, 2010 | 01:13 PM
1978f-250's Avatar
1978f-250
On the off-chance that this is a serious question, I'll answer it for you.
Heater cores don't make noise.
Dennis
Old Dec 9, 2010 | 06:26 PM
PRUSue's Avatar
PRUSue
If you've never done it before I'd allot 4 hrs if everything goes fine. I found that it was nearly impossible to get the heater assembly back into place without undoing the bolt that hold the metal trim of the dash in place (high up on the passenger kick panel) that let it move 1 inch forward. The dash does not need to be removed though. Things to consider:
1) The seals and foam on the heater core cover plate maybe shot- use camper top to make new ones
2) Are your Bowden cables that actuate the controls in good shape? Otherwise buy new ones
3) Remove the glove box, makes thing much easier. Better access to the clip that connects the defrost duct, and the vent cover bolt in the passenger footwell.
Hope this helps. I had never replaced a core before and found it straightforward if you go slow. I also step 2 days repainting the interior plastic panels because I am **** retentive.
Old Dec 9, 2010 | 08:07 PM
jasonnerothin
Dennis
sorry, meant the fan. kinda new to all this.
Old Dec 9, 2010 | 09:32 PM
TOPHER1978F150
Thanks for the tips,guys. I've never done one on a dent but like I said I've done them on Fox Mustangs before.
Where can I get those cables? Do the McParts stores carry them?
I am not repainting any interior parts at this time, I just need heat!
Old Dec 9, 2010 | 10:15 PM
fordracing19's Avatar
fordracing19
I had never done one on a dent and it took me less than 2 hours and mine has ac.
Old Dec 10, 2010 | 12:10 AM
droppedf100
If the fan makes noise either something is stuck in the fan or if it squeals the motor is bad. They are cheap to replace.
Old Dec 10, 2010 | 09:13 AM
PRUSue's Avatar
PRUSue
You can get the cables from places like LMC, NPD, and Dennis Carpenter. I didn't check the local discount places.
Old Dec 10, 2010 | 09:39 AM
mr_ranger-79's Avatar
mr_ranger-79
My fan made all kinds of noise, when I took everything apart when replacing the heater core I found that the fan (and everything else) was all gummed up with pine needles and the like. Cleaned it all up, put it all back together and now you can barely hear the fan! I am so glad I didn't just buy a new one!
Old Dec 10, 2010 | 09:52 AM
78 PEB's Avatar
78 PEB
Also ........even if your cables are not bad.............lube them up while youre in there.......Makes things work a lot easier and keeps em working. WD40 works fine...............
Old Dec 17, 2010 | 09:08 AM
Vaokie1's Avatar
Vaokie1
I replaced the heater core on my 78 F100 w/o ac 302 eng and found it to be a really easy process, it was the first one I have ever done. The repair manual doesn't mention removing the glove box but do it for sanity sake, it will allow easier access to the vent retaining screws and your defrost cable. You may have to adjust the temp and heat/defrost cables after you reinstall everything.
Old Dec 17, 2010 | 09:23 AM
Blown 331's Avatar
Blown 331
As stated if you dont have air it's an easy job. I've done several on Fox Mustangs and 73-79 trucks, there is no comparison. The truck can be done in under an hour.
