Tires
Old Jul 15, 2018 | 11:41 AM
mtntop1's Avatar
mtntop1
Tires
Has anyone used the Michelin Defender LTX M/S 235/75/R15 on their 90 to 95 F150 4x2 and if so how does the truck handle on the highway.currently I have the Michelin Defender LTX M/S P235/75/R15 on my 95 F150 and the truck wanders at speeds above 45mph.I know it's not the front end,it is totally rebuilt including replacing the steering box with a new Mortorcraft one,.Thanks in advance.
Old Jul 15, 2018 | 07:47 PM
Shadow944795's Avatar
Shadow944795
Can't speak for them tires. I can speak for Goodyear Grabbers. They has always driven nicely for my vehicles.
Old Jul 15, 2018 | 07:49 PM
collkid's Avatar
collkid
Unfortunately I would vet its still the steering/suspension.
The LTX has a long history with great reviews.
Old Jul 15, 2018 | 08:03 PM
Diesel_Brad's Avatar
Diesel_Brad
You probably will not beat Michelins on road capability in the stock size
Old Jul 15, 2018 | 10:47 PM
mtntop1's Avatar
mtntop1
[QUOTE=collkid;18088779]Unfortunately I would vet its still the steering/suspension.
The entire front end was rebuilt using all Motorcraft parts so I really don't think it's that.BTW the truck wandered before the rebuild.I'll just replace the tires when the tread wears down. Thanks
Old Jul 15, 2018 | 10:56 PM
Juneaudave's Avatar
Juneaudave
It could very well be a slipped belt on a tire. I wouldn't feel bad about taking your truck into the place you got the tires and having it checked out. You shouldn't have to fight wandering steering.
Old Jul 15, 2018 | 11:10 PM
AK FORD GUY's Avatar
AK FORD GUY
An easy check that you can do yourself is to swap the front and rear tires, then test drive to see if it changed at all.
Also, just because it is all rebuilt, does not mean there is not the possibility of a faulty part or bad alignment causing the issue.
This is a very valid point as well, tires can be defective just like anything else.
Old Jul 16, 2018 | 12:22 AM
TexasGuy001's Avatar
TexasGuy001
If the truck wanders with those tires, which are probably the best street tires you can get, it will likely be worse with almost any other tire. My guess would be a worn steering box if the rest of the steering and suspension is in good shape.
beem1je
Nov 2, 2013 11:01 AM
snydermotive
Sep 6, 2007 06:27 PM
JoeVB
Sep 27, 2006 07:25 AM
400m
Jul 16, 2006 01:38 PM
rocky50
Aug 28, 2000 06:33 PM
