1985 F150 4x4 steering problems
Old Sep 6, 2007 | 01:05 PM
snydermotive's Avatar
snydermotive
Trailering
Well here goes, I'll try to give all the detail I can. I have an 85 F150 4x4 with 165k on the clock. The truck has a real super body for being a Md/ West Va. truck. The problem is that it seem that you are always steering it when you go down the road. I have lifted it with a 4" Tuff Country lift with extended radius arms and replaced the steering box with a rebuilt unit from advance auto. I don't have a steering stabilizer installed on it. As for alignment is there anything that I should tell the alignment shop to adjust to help or do you thing I could have another bad box? I'm listening..................any ideas will be appreciated.
Old Sep 6, 2007 | 01:23 PM
blue beast's Avatar
blue beast
Are you getting bump steer or is it wandering?
Old Sep 6, 2007 | 01:38 PM
snydermotive
Trailering
Wandering, like you are chasing the front around the lane.
Old Sep 6, 2007 | 02:17 PM
blue beast's Avatar
blue beast
Well barring worn out components( jack up truck and hold wheel at 9 and 3 oclock and twist then at 12 and 6 If it moves a bunch then especially at 12 and 6 you got some parts to replace) I would get a double steering stabalizer especially being lifted and if you have bigger tires. Wider tires have more area to grab road irregularies and pull it around. Try dropping your rear tire pressure and see if that helps, What pressure are you running on what size tires?
Old Sep 6, 2007 | 02:59 PM
ri_truck_guy's Avatar
ri_truck_guy
Have you checked the rag joint?
Old Sep 6, 2007 | 06:27 PM
Green Meanie 85's Avatar
Green Meanie 85
Talking
Hello new user,where are you in western md,i'm in allegany co..Yeah i just got an 84 good body 4.9 auto 4x4 800.00,not bad for up here in the mountains!!!
timbersteel
16
May 25, 2016 11:04 AM
nagetech
Jul 1, 2015 02:52 PM
bakos
Apr 13, 2015 07:31 AM
wanguy
Mar 30, 2013 10:18 AM
ChargerFan
Jan 16, 2005 03:38 PM
