I have a 1980 f-150 4x4 that I uses as a daily driver. The truck has 1-1/2" leveling springs in the front and a 3" body lift so I can run 33" BFG's. When I got the truck it was a total basket case. I have since replaced every component steering, wheel assembly, bushings, joints, bearings etc and that means everything including the steering box and a new borgesen streering shaft and all suspension components. The truck rides good and tracks straight (I had a full alignment including adjustable camber/caster bushings installed), but the steering is still vague and twichy. It feels like steering with a rubber band. I know these trucks a predisposed to bump steer which only makes that vagueness worse.
To combat bumpsteer I installed dual stabilizers and bent the stock pitman arm 1-1/4" to correct the steering geometry. Is there anything else out there that I can do to this truck to tighten the steering? Does anybody make an aftermarket steering box that is a tighter with a reduced ratio possibly?
Did you relace the tires with the same size tires? The reason I ask this is I also have an 86' f-150 with a 6" lift and 35" tires and this truck drives great. You would think it should drive worse but it doesn't. Could this be defective sidewall strength or something?
Try temporarily increasing the air pressure in the tires to see if it improves steering response. That should decrease sidewall flex. I had some Generals (1 ply sidewall) on a Chevy C10 that were very "twitchy" if less than 35 psi. Put on some same size Michelins and no problem at all.
I found the answer to my steering problem by accident. I was under the hood working on my plow lines when I need the drivers side wheel turned. My father turned the wheel and that is when I noticed the the frame at the steering box was flexing substantailly. I took the steering box out and found a crack in the frame from top to bottom behind the box. So I welded the frame and added a heavy angle across the truck that ties the two frame rails together with the plow frame to avoid cracking the frame again. The steering feels much better now.
