1978 - 1996 Big Bronco
No start.
Old Jul 14, 2018 | 01:50 PM
Jahud's Avatar
Jahud
No start.
Engine cranks and fires up but when key is released to run position it kills itself, I've replaced started solenoid, ignition switch, and have checked adjustment 100 times. Replaces coil canister and wires. Was running great till I put a new steering column now I'm completely confused. Help!!!
Old Jul 15, 2018 | 07:17 PM
EDC8008's Avatar
EDC8008
It’s the alignment/adjustment. All your troubles started with the column change. Is the new column from the same make, model and year?. Does everything power up on the dash when you turn the key on? Do the accessories work when you put in accessory?
What is your vehicle info?
Year?
Engine?
Transmission?
Hard to help with no information.
Old Jul 15, 2018 | 07:34 PM
Jahud's Avatar
Jahud
Year?
Engine?
Transmission?
1986 bronco w/ 351 and auto transmission. Yes the accy lights turn on once key is first moved to accessory, I've checked that a 100 times it seems like. I was thinking I accidentally knocked off a ground wire during the swap somewhere. I'll check the switch alignment again. Have you ever heard of this happening with a backwards wire on the solenoid?
Old Jul 15, 2018 | 08:21 PM
EDC8008's Avatar
EDC8008
The wires reversed on the solenoid won’t make it act this way.
The only thing I can come up is adjustment. The power for the ignition is common for run and crank, crank just adds the contact for the starter.
I always was was able to align the off position and insert the rod with the key removed and get them to work but it took practice when I was servicing trucks for U-Haul
You can disconnect the battery and the adjust the switch to full contact on the starter at full stroke on the key and try that also.
fastcat1977
22
Jan 30, 2016 09:04 PM
Kommandant
Jan 15, 2012 08:51 AM
smoke1380
Nov 4, 2007 01:35 PM
66MercMan
Sep 10, 2004 11:14 PM
Godder
Electrical Systems/Wiring
May 10, 2004 08:37 AM
