Can't start with key
Old Sep 1, 2004 | 10:20 AM
66MercMan's Avatar
66MercMan
I am trying to get my engine running for the first time in my 1980 F-100. I am using a 460.
I had to run a wire from my coil to my battery and cross the solenoid to start it, because I get nothing from the key. I used an ampmeter to trace the power, and I am getting power all the way into my steering column. I have not yet traced it back from the column.
I have had a starter solenoid go bad but I think I was able to turn the key forward and cross the connections to start it. Should I replace the solenoid or could the actuator in the steering wheel be broken. Is there anything else it could be? I am fairly sure I have wired everything properly, hopefully I don't have to continue tracing wires.
Thanks.
Old Sep 1, 2004 | 11:48 AM
fellro86's Avatar
fellro86
Sounds to me that your ignition switch may have died, if the power goes to it, but never comes out. If it is that way, there is no power to the solenoid to energize it, making it not turn on the power to the starter.
Old Sep 1, 2004 | 11:11 PM
Chiefrider007's Avatar
Chiefrider007
Can you shut it down with the key? If you put the key in the run position, can you use pliers and jump across the solenoid? When you turn the key to acc or run, do you have power inside, lights in dash etc and it just won't crank?
All else aside, I would probably try switching out the control module, about 22 bucks. It costs more than the switch but it's easier to change.
If you could give us more specific symptoms with the original configuration, it would help.
Old Sep 2, 2004 | 09:19 AM
66MercMan's Avatar
66MercMan
I can jump the solinoid to get it started if I have a wire from the battery to the coil.
I have my dash and everything out, so I don't know what other power I have.
NOt sure yet if I can shut it down with the key. I was busy holding the wire on the coil, and I didn't want to run it long because I don't have tranny fluid till I get the new speedo cable installed. I will get ATF and keep testing.
Thanks for the help.
Old Sep 3, 2004 | 09:14 PM
Chiefrider007
Can you jump across the solenoid without the wire to the coil and get it started?
Old Sep 7, 2004 | 08:48 AM
66MercMan's Avatar
66MercMan
No, it won't start without the wire to the coil. I am wondering if it may be the neutral safety switch. I don't think the c6 I put in has one, that may be the problem.
Old Sep 10, 2004 | 11:14 PM
Chiefrider007
Should have been one on the one you took off. Bolts with two bolts on the outside of the shift lever on the trans case. Safety can be wired around by skinning the two wires that goes to the switch and twisting them together. Next, mine did something similar and it turned out to be the Ign. Module, about 22.00 for my 83. Mine lost the ground and caused the truck to start in the run position and not be able to keep her running. The Module is the only thing that has some control over nearly all of the ignition, Ie., fire.....
Leftwardpie
16
Apr 20, 2024 03:57 PM
Bruners4
Feb 9, 2015 11:53 PM
daagitater
General Diesel Discussion
Jun 30, 2011 05:01 AM
kenpobuck
Jan 31, 2011 06:45 AM
rcraig
Jul 21, 2009 03:39 PM
