Diagnosing Overheating
Old Jul 14, 2018 | 10:56 AM
fishfreak101's Avatar
fishfreak101
Just picked up a new rig this week, a 94' F-250 460. Less then a mile a way from where I purchased the vehicle it was getting pretty close to overheating so I let it cool down and drove it to the nearest shop. Sounds like the guy has little time for me so I'd like to diagnose the issue myself.
what I know-
-the trucks radiator is only 1" thick which seems more than inadequate for a big block
-there is RTV around the thermostat housing so it was probably replaced at some point
-The electric fan installed by the previous owner was kicking on
-the truck heats up really quick a couple miles driving or 10 minutes at idle
How do I diagnose the overheating issue as efficiently as possible?
Old Jul 15, 2018 | 07:36 AM
timbersteel's Avatar
timbersteel
Hopefully the last owner or mechanic didn't install the thermostat in backwards....Or used a junk thermostat like Stant. Only use a Motorcraft thermostat on these rigs.
A 1" radiator does seem inadequate for a 460, but I've never dealt with 460's before.
Old Jul 15, 2018 | 08:48 AM
HardScrabble's Avatar
HardScrabble
Temporarily Deactivated
Check the temperature with another thermometer, the temp gauge might be wrong.
I don't think you have the best luck with trucks. You've had some interesting threads. I hope you post an ending to them to tell how they turn out.
A couple things about cooling systems, heat transfer and pressure.
If it makes pressure without heat you have compression leaking into the cooling system.
It leaks if it doesn't make pressure when it makes heat and will boil at too low of a temperature. Rent a kit and pressure test when you have any cooling system problem.
Feel where the heat is and where it is going. If the heat doesn't make it past the thermostat it's bad. If the coolant isn't cooler leaving the radiator, your radiator isn't working. The air off the radiator should cook you.
If someone put the head gaskets in wrong it won't cool right.
Old Jul 15, 2018 | 03:12 PM
fishfreak101
Talked to the shop owner he said he would be okay with me fixing my truck in his lot, and I sure as hell don't have good luck, because after adding another electric fan and replacing the radiator with a 2 1/2" I found that the new radiator was defective!!! I found another radiator and installed it, now it has 2, 16" electric fans and a 2 1/2" radiator its still overheating. The shop is going to test for a head gasket tomorrow. Pray for me or at least wish me luck!!!
Old Jul 15, 2018 | 03:18 PM
fishfreak101
THe truck isn't losing any coolant its making no smoke, and it only has 95k miles.
Old Jul 15, 2018 | 06:49 PM
jplinville's Avatar
jplinville
Check the thermostat to make sure it didn't fail in the closed position...even a brand new one will fail if it's a cheap one.
Old Jul 20, 2018 | 05:23 PM
fishfreak101
It is a confirmed head gasket failure. I got screwed over pretty bad. I only paid 1200 for the truck is it worth putting a head gasket into? I was quoted about 1400. Should I do it myself? I would consider myself pretty mechanically inclined but I have never been in an engine.
Old Jul 20, 2018 | 07:26 PM
Da_Lariat_Chariot's Avatar
Da_Lariat_Chariot
I had a 1" radiator on my 302 for awhile, didn't know there is a 2.5" core available. Ditch that skinny lil thing and get a real radiator.
Old Jul 20, 2018 | 08:09 PM
timbersteel
$1400 for head gasket replacement seems HIGH to me...and considering this isn't a newer engine such as a modular engine...still seems astronomical high.
700-800 seems likely and if you did it yourself, maybe around 300-400.
Lots of idea's.
Old Oct 16, 2018 | 09:11 AM
fishfreak101
Tore the engine down, Looks like it was recently rebuilt. And just my luck its not a blown head gasket but worse there is a crack in the cylinder wall of cylinder 5. I've got a scrapyard engine going in this week, I just hope my bad luck ends there
Old Oct 16, 2018 | 10:28 AM
westcoasting's Avatar
westcoasting
If you're engine was recently rebuilt why not just replace the cracked head?
Old Oct 16, 2018 | 03:40 PM
Binkowski's Avatar
Binkowski
So I gotta ask, did the previous owner say anything about this before you bought it? Have you spoken with them since? Small Claims Court doesn't allow lawyers and it's just you, them and a Judge. You can file the paperwork yourself because fraud is fraud. I bet the minute they get notice of a court date they make you an offer to settle. I just think dumping a problem like that on somebody else is not right.
Old Nov 5, 2018 | 05:53 PM
fishfreak101
Just seeing this now, the owner claimed he hadn't had a problem with the truck, and I'm pretty sure I'd have an advantage since I'm a minor I suppose. When I talked to the owner I was basically told it was now my problem
Old Nov 6, 2018 | 08:06 AM
jas88's Avatar
jas88
He said the crack is in the cylinder wall, ie, the block, not the head.
Almost_Retired_USAF
Modular V10 (6.8l)
15
May 26, 2017 04:01 PM
knecoli22
Jun 23, 2010 10:46 PM
azfordf100man
24
Aug 20, 2007 11:23 AM
Ken86F350
May 19, 2006 06:57 PM
tlb
Aug 7, 2005 01:48 PM
