460 rebuild/ replace
Old Oct 25, 2018 | 02:21 PM
BigBlock25O's Avatar
BigBlock25O
Hello all
Its been a wile since I posted but I have always found the information and members on here helpful. I have a 1996 F-250 powered by a 460. It has 250k on the clock so I would like to swap it out for a fresh motor. I was wondering what the most cost efficient way of doing it ,long block, short block with the old heads machined or a jasper drop in. I would also not like to do a complete engine build (from bare block to complete engine)
Thank you all in advance
Old Oct 25, 2018 | 02:37 PM
HardScrabble's Avatar
HardScrabble
Temporarily Deactivated
https://www.460ford.com/forum/37-eng...efi-460-a.html
The link goes to a recent thread. There are better threads on the same subject.
Do some reading over on the forum I linked to. Engine science has come a long way since these engines were new. Building one from scratch using newer tech makes a huge difference. The two options that make sense to me are the whole build or buy a used engine. You can buy a crate engine with modern tech, instead of building one, but not stock. Rebuilding a stock engine makes absolutely no sense.
Understand dynamic compression ratio and quench, at the very least, before you make up your mind.
Here's another link:
https://www.460ford.com/forum/37-eng...-upgrades.html
Old Oct 26, 2018 | 05:03 AM
'89F2urd's Avatar
'89F2urd
Is the current engine burning oil? Making noises? I wouldn't replace it if it isn't broken, especially with a stock replacement.
Old Oct 27, 2018 | 09:04 AM
Lead Head's Avatar
Lead Head
As others mentioned, if the current engine is running fine and not burning oil, I'm not sure what you'd gain from a fresh motor. I wouldn't expect any major changes in power or performance.
Old Nov 6, 2018 | 10:01 AM
TobyB's Avatar
TobyB
And leakdown and compression tests will confirm that it's still in good shape.
You could even dyno it- that's standard practice for high- performance engines...
At 250k, it very well may be worn out, but $300 worth of testing would prove it.
t
Deederswy
May 3, 2019 01:14 AM
johnvirgil
Dec 9, 2015 08:04 PM
johnson2007
17
Aug 9, 2012 03:50 PM
jimb522
Sep 19, 2007 09:48 PM
