To-do list
Old Jul 11, 2018 | 06:02 PM
90Ford73's Avatar
90Ford73
To-do list
With everything slowing down on the farm, I finally have some time to work on the truck. I've got a small list of things to do, and thought why not make one thread with everything in it.
I'm in the middle of a rad swap again as the aluminum was running a little warm, and I got enough cash to get mine recored. It's suprising how few and far between rad shops are, as the closest one is a little over an hour away.
While I'm doing the swap, I want to change out my block heater as it was making some new noises the last time I plugged it in. I purchased one from Napa, part number 3100043; I've never done a freeze-plug type heater before. The parts guy said to put a little RTV around the O-ring so it seals, but I see online that most people use dish soap or anti-freeze. Which would be best? I got a mini wire brush kit from Napa that I can clean the hole with, or just use sand paper if that doesn't work.
Old Jul 13, 2018 | 03:48 PM
Perk85F250's Avatar
Perk85F250
I wouldn't use silicone. I've seen too many of those little pieces trapped in the radiator or oil cooler. A small amount of soap or antifreeze will be enough to prevent the o-ring from getting damaged. Inspect the power cord to the heater and replace if the insulation is cracked. Just a thought while you have everything apart.
Old Dec 15, 2018 | 06:08 PM
90Ford73's Avatar
90Ford73
Well I didn't keep this thread updated too well now did I? I did finish the rad swap as well as the install on the block heater; that all went fairly smooth. I may be adding a rather big job on my to-do list unfortunately...
First off, thank you Perk85F250; I used some dish soap on the o-ring, but it was probably dry by the time I found the sweet spot and was able to get it in. Anyways, all seems to be well on that front.
I used the truck a handful of times throughout the summer and fall, mainly for dump runs and 8ft box stuff. Otherwise I just zipped around in my little Jeep.
It was probably a couple months ago, as it was cooler but we didn't have snow yet. I loaded up for the dump, Dad jumps in and we take off. We wheeled around for the better part of the day, temps were good everything was normal. I park the truck, and I always slide a garbage bag over the top of the air pot lid just in case my cowl seal leaks (which it does but over the wiper motor, not the lid). I notice that its wet around the coolant overflow tank, but I didn't pay any attention to it. I used it again a week or so later, and same thing; a little coolant pushed out around the overflow cap.
I thought it was maybe a crack in the reservoir, but its all around the cap/neck. I thought maybe it was the rad cap as I had a hassle at the dealership getting a 13lb cap, so I grabbed one from napa in the town I got my rad redone at. I had a new rad and wanted a new cap, and they had only one in stock so I grabbed it. I changed back to my old Motorcraft cap and it still does it, but it looks like the amount is a little less; but still there. I also noticed that the top rad hose gets quite hard upon startup. The thing is, my temps don't seem to be different. Nothing is mixing as my coolant is nice and green and my oil is the same old gloss black. It makes me sick to say it but it looks like I have a combustion leak from a tired headgasket.
My Dad owned this truck before me, and every four or five years the rad would leak and need to be replaced. He bought it in 94 or 95 I think (idk before my time) and just like clock work he would have to do a rad every few years. That is why I'm thinking HG unfortunately. Thing is, he always replaced it with a copper brass of the same thing. It got the same rad over and over again. I changed to an aluminium because of cost (mistake) and ended up redoing an old copper brass as the aluminium was doing strange things. The top rad hose would be collapsed all the time, and the temp would climb sitting there idling. Idk what psi the rad cap was, as it was a little cap like on an F150; it took all afternoon to fill the rad. I think it was a lower psi actually.
Dad was the second owner of this truck, so I'm wondering if the original owner didn't overheat it or damage it somehow, and its been weak from the beginning. Dad always put a copper brass rad in with a 13lb cap and it was fine; then I come along and put an aluminium in and shake things up that much to push it over the edge. I finally got a part time job and was really looking forward to DD this truck; that is why I did all the work to it. I feel comfortable and safe in it. Brakes and tires are new, all oils are fresh, fuel system is new etc etc. My Jeep is a good vehicle, but it needs quite a bit of work to be safe for a DD. I'm a rather large fellow and small vehicles and I don't mesh well; and anything Chrysler is a daytime vehicle as the two cigarette butts they call headlights don't illuminate much. You can't see deer until they're almost venison.
Anyways my rant is over, let me know how you guys would properly diagnose this as a failed HG and we'll go from there
Thanks
Old Dec 15, 2018 | 07:27 PM
Leroy Unlisted's Avatar
Leroy Unlisted
Someone else can probably better explain determining a failing head gasket than myself.
But before taking to heads off, I would try a replacement FoMoCo thermostat..
When mine gave it up, the top hose got hard.. And finally burst, it wasn't opening properly and letting the coolant flow correctly..
Not sure if that would fix it, but either way, it'd be good to do anyways, and it might do the trick.
Old Dec 15, 2018 | 11:40 PM
goodB0Y's Avatar
goodB0Y
The signs of a bad head gasket are:
Over heating because of coolant loss or loss of cooling system pressure... cooling system pressure is needed as it raises the boiling point of water.
White smoke from exhaust... sometimes you can even smell antifreeze in the exhaust.
Coolant in the oil or vice versa... looks like a milkshake.
And external leaks where the head gasket meets the block.
Some say that the head gasket can over pressure the cooling system... but honestly I've never seen that and everytime I've seen a bad head gasket the percieved over pressure is actually the engine overheating from coolant loss. But I'm no expert lol...
engine miss... bad head gasket causes a dead hole from lack of compression.
always start with a pressure test on the cooling system... the testers are pretty cheap at the local parts store or have a shop do it.
pressure loss without noticable external leaks would be a sign...
If it was a gas motor I'd pull the spark plugs as they will tell you as well...
Hate to say it but if it's not oveheating and you see the cap and neck wet and you've checked the rad cap and gasket and maiting surface then its not uncommon for rafs to leak at the neck... sometimes an easy solder fix...
Hope that helps
Old Dec 15, 2018 | 11:56 PM
goodB0Y's Avatar
goodB0Y
Yup... start with the easy stuff first lol
Old Dec 16, 2018 | 05:43 AM
tjc transport's Avatar
tjc transport
i ain't rite
my 88 leaked from day one. i am on my third radiator, and it still leaks a bit at 495,000 miles.
fill it up, and it will leak until the rad gets about 1 1/2 to 2 inches low below the cap.
so i now just leave it about 2 inches low and it stays there.
have to add about 1/2 gallon a year.
as the other guys said, first do a radiator pressure test. that will tell you if you have a leak or not, and usually you will be able to see the leak.
you can also do a coolant hydrocarbon test to check for a bad head gasket, but it is kind of expensive.
Old Dec 17, 2018 | 08:12 AM
Olds64's Avatar
Olds64
Here's a tester to check the cooling system for hydrocarbons:
https://www.amazon.com/Block-Tester-BT-700-Combustion-Leak/dp/B01N1NA22J/ref=sr_1_3?ie=UTF8&qid=1545055678&sr=8-3&keywords=headgasket+tester https://www.amazon.com/Block-Tester-BT-700-Combustion-Leak/dp/B01N1NA22J/ref=sr_1_3?ie=UTF8&qid=1545055678&sr=8-3&keywords=headgasket+tester
Old Dec 17, 2018 | 08:49 PM
DarkOverCast's Avatar
DarkOverCast
I have seen several vehicles add pressure to the cooling system before they actually had a major failure. It's not common but possible.
Next time your drive it and get it up to operating temp shut it off and check the top rad hose the next morning and see if it's hard. As in still holding 13psi. If it's hard you have a slight compression leak, if not then I wouldn't point at a head gasket yet.
Old Dec 25, 2018 | 03:22 PM
Macrobb's Avatar
Macrobb
My '93's original motor gasket failure started as getting overheated once(tensioner failed). After that it would weep a little coolant out the corners of the gaskets when under a heavy load at times(only towing a trailer).
It would also sometimes push pressure out the overflow, make a few bubbles.
When it finally failed(a year after the overheat), it went to coolant in the exhaust and constant bubbles in the overflow when running. I never saw the coolant temps get above 200 at any time around there.
I ended up starting it and moving it 5 times between then and when I pulled the motor for a re-gasket. Fired right up each and every time, on all 8 cylinders.
Old Dec 25, 2018 | 07:46 PM
90Ford73's Avatar
90Ford73
Thank you guys for the insight so far. I finally got a T-stat from Ford the other day, and will be swapping it out as soon as I have time; probly won't be for another week or more unfortunately as its getting cold here. I might change it and take it to work on a Saturday or something to see how it does. I will post the results after I change it; hopefully its something simple lol.
Merry Christmas everyone!
Old Jan 6, 2019 | 09:15 PM
90Ford73's Avatar
90Ford73
Hey guys it’s been awhile, hope everybody is having a good start to the new year so far.
It was warm a few days ago, so I was able to swap tstats. It was much easier than I thought tbh. Everything went very smooth and I was finally able to dump coolant in it tonight and fire it up.
I plugged it in for about an hour as the starter is getting weak and cranking slow. It fired up alright and I didn’t see any leaks so far.
I let it run for about 20 min or a little longer, and the temp slowly crawled up to not quite 180. The rad was too warm to keep my hand on, and the top hose was warm and soft with little to no resistance when I squeezed it. The overflow level had risen, but I’m assuming that’s because everything was getting hot.
I lost more coolant than I expected to, so I’m sure I didn’t get all the air out of the system from just idling. I was tired and didn’t take it for a test drive lol I know I should have. I’ll use it in a couple days and see what happens.
Usually within a couple minutes the rad hose was hard, but it was soft after 20 min of idling. Even with air in the system, that shouldn’t affect the top hose from being hard if it were a combustion leak right?
I did indeed boil the new tstat, and it seemed to open around 192 like it should. The check ball and cork were intact and working inside the housing.
When I popped the old tstat out, I had to use a wrench and hook the top of it to get more leverage as it didn’t want to come out. When it did come out, it looked a little different but I didn’t clue in. The coolant drained down and was level with the block. I figured I could take some hose and siphon it down (I couldn’t because it’s shallow). I stuck the hose in and started sucking on the ends and I hit the rubber that used to be on the tstat and it popped up. While looking at it and wondering where the other 80% of it went, I got a mouthful of coolant because I’m an idiot that wasn’t paying attention. I’ll post a pic when I setup my laptop, but there’s lots of rubber missing that the water pump probly ate.
Anyways let me know what you guys think, and I’ll update again when I actually drive it
Old Jan 7, 2019 | 12:55 AM
Leroy Unlisted
You know, one time - when my coolant was drained.. It wouldn't prime, or take in enough at the radiator to get it flowing.
Other times it did okay, but once it just couldn't get it started to circulate.
Trick was to take off the heater core hoses, one pulls, one pushes. And I used a funnel to pour coolant into the pull side to get it started. Maybe just fine, but give that a shot if it won't take it up.
Old Jan 12, 2019 | 08:48 PM
90Ford73's Avatar
90Ford73
Hey guys I’m back with an update. I checked the coolan level after the initial start up and it was full in the rad and full in the overflow. The overflow was a bit down before but I figured it got warm and dumped some from the rad.
Took it to the other place which is about seven miles each way and it never got past 180 on the temp gauge. The old tstat would get to 192 while idling long enough, while this one will only get to 160 or so then it warms up to 180 while driving. This morning it bounced back and forth from 180 and down, but I figured it was just working the air out.
I didnt see any coolant on top of the overflow bottle on the way there, but when I got home there was a decent amount around the overflow bottle cap. What I don’t get is that the rad hose is soft now. Soft while running and soft after shutdown. I can still squeeze it after it’s warm, like there’s almost no change in pressure, or just a slight bit more when warm. The rad is warm, so we should be circulating coolant. How can I be sure we are? The heat in the cab isn’t great, but about the same from before I changed the tstat. It still defrosts and keeps everything from fogging, but it doesn’t cook you out like I seen on other posts that these engines do.
I don’t see how it can push it out the overflow bottle while having a soft rad hose. If it was a combustion leak the hose should be hard still right? I did notice there was a few bubbles coming from the front of the drivers side head where the head gasket is, but that’s external. I only seen it because it was dark and I had the flashlight on there, and I seen the bubbles amongst the caked on oil and grime.
When I changed rads and added coolant, I added concentrated anti freeze because I couldn’t get distilled water in time. I added more straight antifreeze to it when I changed tstats, and I planned on adding water this summer. What I’m getting at is that I have a high concentration of antifreeze; that wouldn’t have any effect would it?
Anyways, I’m gonna drive it and see if anything changes. Let me know what you guys think; thanks for reading the long post
Old Jan 13, 2019 | 04:58 AM
tjc transport
i ain't rite
pure antifreeze without water is no good, it will turn to slush when cold. you need to dilute it.
