Sponsored by: Auxito
Injector oring leaking Please Help!!
Old Jul 11, 2018 | 02:53 AM
whiteboyinc's Avatar
whiteboyinc
I have a 2001 ford f150 4.2. I replaced the upper and lower plenum gaskets to fix other issues and codes i was getting.Also replaced fuel injectors since i was right there and figured it would be best.Everything is together runs great no codes but i have an injector leaking fuel .1 i can smell it around the cab and 2. i can see it puddle up around it.Ive since went back in and replaced the orings on that 1 leaking injector but it still leaks.Can someone please help me out here...TIA
Old Jul 11, 2018 | 05:40 PM
steve(ill)'s Avatar
steve(ill)
I would pull that injector and make sure it is not cracked or damaged... if you have installed the o-ring twice and it still leaks.. look deeper.
Old Jul 11, 2018 | 05:45 PM
whiteboyinc
The injectors are all brand new,Just this single one leaking is giving me trouble,when i pulled it again to replace the orings i inspected it and everything looked fine as the day they were installed,thats what has me stumped.
Old Jul 12, 2018 | 06:03 AM
jughead808's Avatar
jughead808
Make sure you didn’t leave an extra oringbin either the manifold or the fuel rail, keeping it from fully seating.
DBGrif91
Feb 11, 2018 10:30 AM
kefrko
1983 - 2012 Ranger & B-Series
Apr 5, 2016 10:31 AM
SMarquez
Modular V10 (6.8l)
Jun 22, 2012 07:10 PM
carrcreekcaller
Apr 30, 2012 10:55 AM
biglurp
Sep 14, 2001 08:11 PM
