Tuning a spare computer?
Old Jul 10, 2018 | 09:31 PM
93notch's Avatar
93notch
Does it make sense to get a spare Ecu to install and then tune / delete your truck? Anyone ever do this to a vehical? Not sure if it would hide everything from a dealer if/when you take it in for warranty work. or if this idea would work in general. Seems like you could return it completely back to stock.
Old Jul 11, 2018 | 01:00 AM
VQ2Fast4U's Avatar
VQ2Fast4U
I just had the ring and pinion replaced in my truck under warranty. Brought the truck in tuned and deleted, the dealer couldnt have cared less. Unless you melt a piston or burn up a transmission I cant see the warranty being voided.
Old Jul 11, 2018 | 04:43 AM
seville009's Avatar
seville009
much easier and cheaper to simply return it to stock before taking it to the dealer
Old Jul 11, 2018 | 05:59 AM
Blwnsmoke's Avatar
Blwnsmoke
It will not work, the ECU is programmed to the truck and multiple other computers as they all communicate together. You can not swap ECUs without reprogramming all the other modules to work together.. your truck will not start. No point in doing this any more.
Old Jul 11, 2018 | 06:35 AM
93notch's Avatar
93notch
thanks for clearing that up, figured with all the computers on the new trucks something wouldn’t line up. Probably just gonna delete and keep all stock parts.
Old Jul 11, 2018 | 07:37 AM
TXKR0317's Avatar
TXKR0317
VQ2Fast, would you mind sharing your delete/tune solution?
93notch, not meaning to hijack your thread. Solid question though.
Old Jul 12, 2018 | 12:03 AM
VQ2Fast4U's Avatar
VQ2Fast4U
I just run an ezlynk tuner with all the common hardware that goes along with a delete, nothing out of the ordinary. Im just waiting on ezlynk to release all the baseline parameters so I can write my own tune, im not a fan of the currant files offered by the techs.
Old Jul 12, 2018 | 12:40 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Sounds like fraud to me.
Returning the computer to stock won't get rid of all the evidence that there was a tuner installed. There is software in the truck (no, I won't say where) that can detect when the engine makes more power than stock. When it sees this it sets a code that is stored away from the engine computer. If you can find this code you'll also find that you can't delete it. The dealers can find the code and if they do, they can deny a warranty claim that could be due to more power than stock.
I know about this because I was at Ford when it was developed. I worked with the people that created this software. I won't argue whether it exists or not, nor will I describe how it works. I really don't care if anyone believes me or not, I post this for the benefit of those that are concerned about keeping their warranty intact.
Old Jul 12, 2018 | 02:20 PM
SolarDeity's Avatar
SolarDeity
Sounds like it's in the transmission from your signature..............
SD
Old Jul 12, 2018 | 02:36 PM
ford390gashog's Avatar
ford390gashog
Part of it is in the transmission and built in to the torque management. If you have the money and access to IDS its not hard to create a second ECU. You just have to have access to the as built data and you can link everything including all modules. I don't advocate doing this but I also don't see it as a problem. It's so cost prohibitive for most people that it would never become a widespread issue. Look up the cost for the ECU and the core charge.
rjrandy96
6.7L Power Stroke Diesel
Sep 29, 2018 10:31 PM
txazguy
79
Apr 23, 2016 04:17 PM
kellygh
Aug 24, 2009 10:24 PM
stackedstroker1
Jul 24, 2009 05:28 PM
w_huisman
May 19, 2009 05:17 PM
