48-50 cigar lighter
48-50 cigar lighter
so I happened up on this accessory, the cigar lighter. Any thoughts on how to wire it? It didn’t come with instructions. Thinking the lighter element would hit the acc stud on ignition but what about the light? The light wire is longer which makes me think it hits another power source? Not sure if it is long enough to hit the headlight switch.
JB
My guess would be the light is wired to the headlight switch so it only lights when your lights are on. I don't know much about 48 to 52 trucks but the lighter has a bracket, so it doesn't have a specified spot on the dash like the 53 to 55 trucks do? So mount the bracket close enough so the light wire reaches.
It has an under-dash mounting. I would check for pre-drilled holes that match (I think there is a pair underneath the ignition switch). The lighter element should go to the load side of one of the circuit breakers, and like others have said, the light would go to the dash or headlight switch, whichever is most convenient. There is also a flat round spot under the ashtray where it could be installed in the dash.
The dash was pre-drilled and it mounted up nice. I hit the H stud on the breaker box and wired the light to the taillight circuit on the switch. I don’t smoke but it looks cool and the real bonus is that now I can use my ford accessory utility light! It lit up nicely.
Thanks for the help.
JB
vwfreak
11-06-2013 06:21 PM
johninraleigh
12-22-2007 11:05 AM
