New engine or rebuild
Old Jul 8, 2018 | 10:27 AM
Curtis Hoard's Avatar
Curtis Hoard
Hello all . I have a 92 flareside with a 5.8 in it . She is tired and has some lower end knocking . I am looking for recommendations as far as should I get a remanufactured engine and if so where at ? Or should I just have mine rebuilt . I’m looking for the reliable option as this truck is in great shape for its age . Thank you all for your time
Old Jul 8, 2018 | 11:05 AM
BigBlue 94's Avatar
BigBlue 94
Either would work. Depends on whether you have another ride or not. If you only have a weekend, a new crate engine would be the ticket. If you have some time, rebuild what you got. Either way is gonna cost about the same.
Old Jul 8, 2018 | 01:23 PM
GoinBoarding's Avatar
GoinBoarding
I'd rather rebuild what I have, so I know exactly what I have. Reman isn't always done to the standards you'd like, and isn't as conducive to upgrades like gt40 heads, a better cam, etc. If you have the time, ability, and a reputable machine shop available I'd rebuild. Do your homework if going this route.
Assuming your current block is a good core, one conundrum is whether you want to use your non roller lifter block (then decide flat tappet or link bar roller lifters) or get a roller (94'+) block for a roller cam setup. 94'+ blocks have a known cam bearing crack issue (though I've never seen this actually cause a problem), and link bar lifters are expensive, but modern oils aren't meant for flat tappet cams either.
Anyway, just food for thought.
Old Jul 8, 2018 | 01:26 PM
BS51993's Avatar
BS51993
Rebuild would be better than remanufactured. I have seen handfuls of bad reviews about remanufactured. One horror story was about a head gasket that blew a week after installation at only a few hundred miles.
Fordman96
Jan 26, 2012 06:52 AM
hivoltj
May 23, 2011 01:22 PM
oldwood
Jan 26, 2011 09:55 PM
F-250beast
Dec 30, 2007 10:23 PM
tonpartain
Sep 6, 2006 11:39 PM
