Swapping 2008 engine in my 2005 lariat; no oil sensor
Old Jul 7, 2018 | 10:08 PM
hivoltj's Avatar
hivoltj
So, I swear I looked but apparently didn't. This '08 engine doesn't have the damn sensor. I thought no big deal, it's just a low oil sensor. Doing a little reading apparently it's a oil temp sensor as well. Any work around or am I pulling the pan on this sumbitch? Motor is now installed btw.
Old Jul 7, 2018 | 11:42 PM
steve(ill)'s Avatar
steve(ill)
Have you tried starting the motor and seeing what happens ? Is it really needed .
Old Jul 8, 2018 | 12:25 AM
ford390gashog's Avatar
ford390gashog
It's a temp sensor. It's also a very inaccurate POS! Hence why they dropped them starting mid 07. It's not a low oil sensor.
Old Jul 8, 2018 | 04:57 AM
redfishtd's Avatar
redfishtd
@ford390gashog
^^^ what he said Tape it to oil pan maybe
Old Jul 8, 2018 | 07:12 AM
hivoltj's Avatar
hivoltj
I'll give that a try. Oil pan comes off without pulling the motor, right?
Old Jul 8, 2018 | 08:40 AM
steve(ill)'s Avatar
steve(ill)
Why pull the pan ? Just tape the plug to the harness and forget it.
Old Jul 15, 2018 | 09:04 AM
hivoltj's Avatar
hivoltj
I did just zip tie it to the trans cooler line block, seems fine so far. I thought this truck had an oil life monitor but, clicking through the menu, apparently not.
friskyjake
Mar 20, 2017 02:21 PM
Reap3r
2004 - 2008 F150
Jul 31, 2014 01:16 PM
ltlvt
1983 - 2012 Ranger & B-Series
Sep 23, 2013 02:08 PM
brad7.3
Aug 20, 2006 09:37 PM
teg3
Aerostar
Jun 16, 2004 01:18 PM
