Modular V10 (6.8l)
IDLE HESITATION
Old Jul 7, 2018 | 12:17 PM
handifletch's Avatar
handifletch
IDLE HESITATION
Getting ready to do a full swap of coils,injectors and plugs but I want to get a handle on an idle (possible problem). Truck is warmed up driving and running perfect, slow to a stop and there is a noticeable delay before I drop to about 700 rpm idle. The truck runs fine but the delay to idle is kind of annoying when breaking to a stop. I also have to give it about 2 seconds before shifting from forward and reverse as to not buck the tranny. Appreciate any input.
Old Jul 7, 2018 | 06:46 PM
maticuno's Avatar
maticuno
Check to make sure the throttle cable isn't too tight or too loose. Cleaning or replacing the IAC valve might also be in order.
Old Jul 8, 2018 | 11:49 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
That's exactly the symptoms of a sticking IAC.The PCM tries to adjust the IAC for it's intended idle, finds that it can't, and adjusts other things to accomplish it. I think it does it by retarding the timing. Which affects a lot of other things, and will make it run "weird".
TheV8tractor
Mar 23, 2015 04:29 PM
stsscott
Oct 14, 2010 06:33 AM
fire232
Sep 16, 2003 08:44 PM
dynamic
Aug 17, 2003 06:43 PM
