CRAZY IDLE ??
Old Oct 12, 2010 | 05:02 PM
stsscott's Avatar
stsscott
CRAZY IDLE ??
HI ALL:
PUT A 93 5.8 IN MY 92 F-150 THAT HAD A 5.0 GO SOUTH, IT'S BEEN RUNNING GOOD UNTIL LATELY.......THE IDLE HAS BEEN GOING ALL OVER THE PLACE, MOSTLY UP. I REPLACED THE IDLE ACTUATOR VALVE, IT WAS RUNNING OK, FOR A COUPLE WEEKS BUT NOW THE THING JUST WANTS TO RACE, THE IDLE STAYS UP AROUND 2,000 RPMS. ANY IDEAS WHAT ELSE COULD CAUSE THIS
THANKS IN ADVANCE
SCOTT
IF I DISCONNECT THE IDLE CONTROL VALVE, THERE IS NO MORE IRATIC IDLE BUT IT STAYS REAL LOW?????
Old Oct 12, 2010 | 05:31 PM
DBGrif91's Avatar
DBGrif91
Check thoroughly for vacuum leaks.
Old Oct 13, 2010 | 08:49 AM
rla2005's Avatar
rla2005
Also check the throttle cable and the throttle body.
Old Oct 13, 2010 | 10:25 AM
stsscott's Avatar
stsscott
Old Oct 14, 2010 | 02:08 AM
TexasGuy001's Avatar
TexasGuy001
I would think that would indicate that the IAC valve is not sticking then.
Old Oct 14, 2010 | 06:33 AM
DBGrif91's Avatar
DBGrif91
Like I said, check thoroughly for vacuum leaks.
skotyg
Oct 24, 2012 02:08 PM
mark227
Jan 1, 2012 09:56 AM
skeith5
93
Nov 21, 2010 07:28 PM
Rockledge
1983 - 2012 Ranger & B-Series
May 27, 2006 06:20 PM
Scott99Z
Feb 7, 2004 02:39 PM
