Oil pressure concern
Old Jul 6, 2018 | 07:57 PM
JohhnyVW21's Avatar
JohhnyVW21
So I have a 1991 ranger 2.3 lima and long story short i did a cylinder head gasket and new head. The problem im having now is the oil pressure needle not reading right. When i start it cold needle read fine as truck starts to warm up it goes haywire and just goes to L in red zone, however if i hit the gas it goes to normal but when coming to stop at idle it goes back to red zone, I dont here any unusual noises coming from lifter or pump however I changed the sender unit already and its still doing it and i did a pressure test and it was reading 24psi when cold. Could this be a wiring issue or oil pump? The truck throws no engine codes or anything it actually running pretty smooth. I heard the oil screen can get clogged and cause this issue could it be that? I have a inspection camera to put in oil pan.
Old Jul 6, 2018 | 09:50 PM
wtroger's Avatar
wtroger
That’s to low for cold pressure should be about that hot
Old Jul 7, 2018 | 06:55 AM
pawpaw's Avatar
pawpaw
Were you having this problem Before the work?
Old Jul 7, 2018 | 10:43 AM
JohhnyVW21's Avatar
JohhnyVW21
So would it be the oil pump or screen? Im going to see what is the psi when hot.
Old Jul 7, 2018 | 10:44 AM
JohhnyVW21's Avatar
JohhnyVW21
Not at all it just started doing it, I was thinking a wiring issue.
Old Jul 7, 2018 | 11:29 AM
Hank85713's Avatar
Hank85713
easiest to do is hook up direct reading gauge and see if you have oil pressure or not. If it reads ok then you have a wiring or sender issue. I basically had same problem and installed a sender on the oil filter. Got it and gauge from Glow Shift.
Old Jul 7, 2018 | 12:40 PM
JohhnyVW21's Avatar
JohhnyVW21
I did on cold start it was reading 24psi i believe i will double check i havent did warmed up psi which is when it goes wonky so I will do that tommorow, im going to get a oil cleaner dump in engine and let it sit over night.
DJdemon6696
Jul 12, 2007 09:24 PM
scraig
1978 - 1996 Big Bronco
Jan 20, 2007 06:40 AM
tundraathome
Jan 12, 2007 10:46 AM
gdig40
19
Nov 1, 2006 05:51 PM
kopfenjager
18
Jan 5, 2004 10:08 PM
