oil pressure problem
The problem is a idle cold my oil pressure is 80 psi and warm is at 40psi. what can I do too fix the problem.
Not trying to inflict harm cause I am a Cummins diesel man, but extreem fluctuations in oil pressure from startup though normal operating temperatures is normal. "80" startup, "20" warm idle, and "40" cruise mode is typical. But we also use a 15W40 viscosity motor oil that takes time to thin out. That's why I wonder if your using too thick a viscosity?
I do know a thing or two about motor oils and lubricants. My dad worked for Kendall Motor Oil Co., for 38-years before Kendall folded and sold out. They're oil is still available but not for much longer. But NEVER use Kendall or Quaker State motor oils in a Ford engine. They break down faster than Penzoil and Valvoline, and can leave harmful sludge in your engine.
Another thing, if you choose to use Kendall or Quaker State, change your oil at exactly or before 3000 miles or you'll learn about the damaging sludge I'm talking about. With Penzoil or Valvoline, there is a comfort zone that allows you to actuall go over 3000 miles without harm to engine.
And as always, never use silicone based oils in a new or freshly rebuilt engine. Give engine time to age and break-in before using those type of oils. Never add additives to engine oil!!! They are not needed, and may in fact hurt engine rather than protect it. As long as motor oil is changed when it should be, you'll never have any trouble from your motor.
If I upset anyone I'm sorry but these things must be said and one of the biggest failures in piston engines is the failure of the owner to use the proper grade of engine oils and change engine oils in a timely manner. That's all I have to say.
I use Valvoline tho... You can find more info about oils in the Lube forum here.
I am going str8 to the Lube forum from here because I'm real curious about this deal with Penzoil. I personally have been very happy with Penzoil and Vavoline for a long time running and have had absolutely no trouble whatsoever. If there is some news here I need to know about it.
As I have replied to another gentleman tonight about this same issue, I as well with only 103,000 miles on an engine that is 31 years old am starting to notice my oil light flickering while stopped and in gear. Engine sounds fine and gives no indication that there is any problems in the bottom though I know when an oil light comes on, the main bearing clearance has increased. I have already changed the sending unit and that put the light out but tonight it just started lightly flickering. But if there is a problem with Penzoil, I really would like to know about it and see if others are having the same problem with older engines. Off to the Lube forum I go.
_________________________________________________
1973 Ford Country Sedan station wagon 6.6L 400/V8
I am going to try something I saw mentioned in another forum of adding Mavel Mystery Oil to my existing oil and clean it out then I'm making an immediate switch to Valvoline MaxiLife 10W40. Judging by what I've read (and I have ready alot on this site), many many people are happy with that oil and give it strong recommendations.
In trucking there is only one oil that I have ever used with diesels and that is Rotella Shell 15W-40. I usually run oil for 10,000 miles or 1-month before changing oil.
I'm so thankful for the information I have found on the FTE site and am glad I have joined.
__________________________________________________ __
I appreciate your recommendation and am switching to it soon. I wish I had known before about Penzoil. I've been using that oil for years and didn't know that it was just like Kendall and Quaker State motor oils. The only reason I pushed Kendall in past years was for business reasons. I am the Kendall kid. My dad was working there before I was born in '66, and I have some cute pictures of me growing up around the company. But I always knew that Kendall was recycled motor oil just like Quaker State. So I never used it in my cars. But since Kendall doens't exist anymore except by name and products will cease sometime in near future, no sense going on and on about that name.
When I was 18 years old, I was a truckdriver for Kendall too just like my dad until Valvoline convinced me to come over to their side. I drove for them for awhile then quit. But continue endorsing they're product even to this day. I was also a gasoline tanker driver for Flying J truckstops and driver and oil tech for Chevron Oil on the west coast. Though today I pull a tanker hauling cement, I have nearly 20 years in the trucking profession. I spent many of those years working on trucks too but very little working on cars. Never liked cars. But I have one for now but as soon as it sells, thats probably it. My light truck of choice is the 1979 Ford full-size ranger. Maybe one day I'll have one. Maybe I can trade this station wagon for one. But needs to be like for like. Car is 90% and truck needs to be about same. I don't drive rust buckets.
1973 Ford Country Sedan station wagon 6.6L 400 V/8 Florida car
Ok guys, it's official. The divorce is final effective tonight. The Penzoil is out of my engine and was replaced by Valvoline Maxi-Life 10W-30. And I used a Motorcraft oil filter. But heres the funny part, and I blame it on this FTE website, when I went to Autozone to buy the oil, there was a line of guys just like me at the counter. EACH one of them had a case of Valvoline Maxi-Life. The rest of us were in the back of the store scavenging for what Max-Life that was left. Now read this carefully guys, all the other motor oils on the shelves including Valvoline Dura-Blend, and All Season were this on the selves completely full racks. The Maxi-Life shelves only had three cases left. I and the two guys behind me grabbed what was left which was 1- 10W-30, 1- 5W30, and 1- 20W-50. I grabbed the 10W-30 and ran to the front of the store. It was funnier than hell to watch.
When I asked the manager about the Maxi-Life by Valvoline, he exclaimed " I can't keep it on the shelves". He can't get rid of the other oil brands, and can't get Maxi-Life trucked in fast enough. So since it seems that all these guys including myself are members of this FTE website, way to go guys. And I'm truly sorry for bumping that one out of the way. If your reading this, I appologize but only until the next oil change then we're going to have to dance again. LOL, LOL, LOL.
It was just the funniest moment I've had in a while. I should've bought stock in Valvoline this past weekend. To the rest of you out there, the shelves are probably bare at the moment, but the next truck delivery comes in a couple of days. Then you better be there in front of the doors at least a couple of hours before the store opens if you want to share in the fun. Reminds me of the Cabbage Patch dolls when they first came out........
