oil pressure
Old Jan 9, 2007 | 10:57 AM
tundraathome's Avatar
tundraathome
oil pressure
i have a 93 ranger with a 3 l engine. i have replaced the main and rod bearings, new oil pump and the pressure now sits at 55 cold and about20 when warm[mechanical guage] the warm psi seems to be on the low side as i woul think that a spread of about 20 psi between hot and cold should be about normal. sam
Old Jan 9, 2007 | 06:00 PM
MazdaRangerGuyInSTL's Avatar
MazdaRangerGuyInSTL
HOT oil pressure, at 2500 RPM should be 40-60psi.
That's the only oil pressure spec I can find.
Good luck
Old Jan 10, 2007 | 10:00 AM
tundraathome
that is about what i thought . are there any other items unique to this engine that i should be looking at. the engine was very clean inside when i took it apart sam
Old Jan 10, 2007 | 07:29 PM
MazdaRangerGuyInSTL
20PSI at idle should be fine, just as long as it's above 40 when you rev it up above 2500 rpm.
Old Jan 12, 2007 | 10:32 AM
pawpaw's Avatar
pawpaw
The 3.0L oil pressure of 40-60 psi @ 2500 rpm is all I've found specified also.
I think MazdaRangerGuy is about right.
My old Merc Zypher, with the 3.3L, using 10W-30, with the specified thermostat & fully warmed up at idle, indicates about 15-20 psi & about 50-60 psi off idle, on it's oil pressure gauge I installed, depending on the rpm, engine temp & oat.
Old Jan 12, 2007 | 10:46 AM
fordboy_52's Avatar
fordboy_52
thats pretty much what im getting with my 3.0l and my manual guage
Matt
