Do these tuners really add 100hp
Old 07-07-2018, 01:52 PM
Sous's Avatar
Sous
Sous is online now
Received 4,466 Likes on 2,855 Posts
Originally Posted by Stewart_H
The 7.3L Excursions didn't have cats. The gassers and the 6.0L powered Excursions however did come with a cat.
I believe all E99 trucks came with cats too, and most hand-shakers from the L99 and up rigs will have cats too. Can't remember the rhyme and reason for it, but they did.
Stewart
If it helps at all, my truck which is a 2000 ZF6 built in December of 1999 did NOT have a cat on the OEM exhaust.
Old 07-07-2018, 03:06 PM
SaintITC's Avatar
SaintITC
SaintITC is offline
My e99 handshaker does have a cat, but I seem to recall other e99 owners posting no cats in other threads. Really, the only way the OP can determine what came on his truck is to read the emission sticker on the valve cover. It's on the passenger side valve cover on my F250, can't say for sure if it's the same for vans. And it's practically impossible to read with the IC pipe installed. I know vans don't have intercoolers, but I'm sure there's something blocking your view!
Edit: Someday I guess I'm gonna be looking for another 1999 pass valve cover ...
Old 07-07-2018, 06:49 PM
hydro man 17's Avatar
hydro man 17
hydro man 17 is offline
"I believe all E99 trucks came with cats too, and most hand-shakers from the L99 and up rigs will have cats too. Can't remember the rhyme and reason for it, but they did."
From what I have been able to glean is that mid '99 on had no CAT as long as it was an auto trans. The manual trans versions had a bit more HP and required a CAT for some reason. I don't think that the HP difference is all that much but I guess there is some threshold requirement. But as SOUS points out, there are no absolutes in life.
Old 08-19-2019, 07:34 AM
octaneforce's Avatar
octaneforce
octaneforce is offline
Hey everyone sorry to bring back an older thread but i finally did a 4 inch exhaust on the van. Its a diamond eye turbo back. Sounds great and helped uncork the truck a bit. I want to get a tuner and i think im leaning towards hydra. Heres what im looking at
https://www.ecddiesel.com/power-hung...-for-ford.html
Old 08-19-2019, 08:09 AM
Walleye Hunter's Avatar
Walleye Hunter
Walleye Hunter is offline
Do you have EGT gauge yet? Don't forget that your E model does not have an intercooler on it (unless you found a way to squeeze one in there).
Old 08-19-2019, 08:56 AM
octaneforce
No the egt guage is also on my list. Truck is stock minus the exhaust.
Manufacture date is march 1999. Does that make this an early 99 as opposed to a 99.5? Or does it not matter on the vans?
natedlee
Computer Chips & Tuners
08-18-2019 07:24 PM
insufishentfunds
1999 to 2016 Super Duty
06-09-2015 09:12 AM
1L243
10-08-2011 08:56 AM
r-kid
06-30-2009 08:07 PM
Quick Reply: Do these tuners really add 100hp
