Babe the Blue Ox is SICK!
  #121
Old 07-17-2018, 08:36 PM
oldbird1965's Avatar
oldbird1965
oldbird1965 is offline
I concur also. Its the 'if' its a good motor that I'm curious about. I'm sure it will work out OK. If they can offer unlimited mileage warranty for the first year they must be good.
  #122
Old 07-17-2018, 08:41 PM
oldbird1965
Originally Posted by 427 fordman
Thats what I will be doing to mine when it goes back in. Working it hard, best way to break it in. My race car gets 20 minutes of break in at varying rpms between 2&3k, then drop the break in oil, put in new and run the crap out of it.
Sounds good Darin. The shop told me today they will do the reving it up then dump the oil and for me to change it between 500 & 1000.
  #123
Old 07-17-2018, 09:32 PM
BBslider001's Avatar
BBslider001
BBslider001 is offline
I'd be listening to Darrin fost and foremost. He's been there, done that. That's pretty darn cool they will be doing the break-in for you.
  #124
Old 07-18-2018, 09:41 AM
Airstreamer67's Avatar
Airstreamer67
Airstreamer67 is offline
Glenn, I hate to hear about the Blue Ox woes. That truck lives a demanding life pulling what, 18K? Wow. How many miles do you have on that engine?
  #125
Old 07-18-2018, 12:08 PM
oldbird1965
Only 134K. This picture says it all:
This picture I just don't know??
  #126
Old 07-18-2018, 12:11 PM
RÖENTGEEP's Avatar
RÖENTGEEP
RÖENTGEEP is offline
FOREIGN GURU
OOOOPS! Now call CSI to find out the cause of that turbo wheel?
  #127
Old 07-18-2018, 12:22 PM
oldbird1965
The boss wasn't there and the guy working on it didn't know. Here is some more mystery:
Uneven distribution of the water injection?
  #128
Old 07-18-2018, 12:27 PM
oldbird1965
This should cure most of the problems! I could have sworn yesterday it was painted black!
  #129
Old 07-18-2018, 12:33 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Talking
Maybe ligth BLACK
  #130
Old 07-18-2018, 03:03 PM
Hussler's Avatar
Hussler
Hussler is offline
Wow Glenn, great pictures. I'm turbo stupid so is the picture the exhaust side or intake side? Guess I could understand the damage if it was the exhaust side as a chunk of the piston probably went through it. Read somewhere #8 cylinder always runs hotter than the rest, don't know for a fact though. Keep the faith, brand new engine and you should be good to go. It will be interesting to see your reports when you take off with the beast and overall performance compared to the old engine.
  #131
Old 07-18-2018, 03:41 PM
oldbird1965
For some stupid reason i didn’t look at the intake side. Seems like I’ve heard #8 runs hotter, a fueling issue??? Might be time for a sxe. Might also be time to do away with water injection.
  #132
Old 07-18-2018, 04:11 PM
strokin'_tatsch's Avatar
strokin'_tatsch
strokin'_tatsch is offline
The damage to the turbine wheel looks like it could have been a result of the broken piston. It looks like there's a small piece of the piston missing which would have hit the turbine wheel.
Where are your water nozzles located and are they spraying into the center of the piping?
  #133
Old 07-18-2018, 04:29 PM
fordman67's Avatar
fordman67
fordman67 is offline
How the heck could the charger get that damage tho? I am floored really. The piston suxs but with the symptoms I kind of figured that would be the case.
  #134
Old 07-18-2018, 05:41 PM
z31freakify's Avatar
z31freakify
z31freakify is offline
Received 1,192 Likes on 818 Posts
Probably the chunk of piston damaged the exducer.
  #135
Old 07-18-2018, 05:48 PM
oldbird1965
IDK, can it be repaired or do I replace it? Man, I want to get out of here and don't want to wait on parts, grrrrr. I can put on a new turbo next winter when I'm at home. Sorry, just venting. 366SXE??? 369SXE???
Quick Reply: Babe the Blue Ox is SICK!
