remove ball joint from axle
Old Jul 4, 2018 | 04:34 PM
gmammakn's Avatar
gmammakn
So the upper ball joint is stuck inthe axle. There is rust, and I mean a lot. The threads were rusted away so I had to cut the nut off.
No I am looking at the washer thing on top of the axle where the ball joint goes in with the top of the ball joint flush with it (I tried pounding it down and mashed the threads and bent it.
I got the biggest pickle fork from autozone and drove it all the way in. No luck. Beat it silly with a hammer. Nada.
Any suggestions?
Old Jul 4, 2018 | 05:50 PM
pirate4x4_camo's Avatar
pirate4x4_camo
FTE Remembers
Originally Posted by gmammakn
Any suggestions?
Hit the C with a BFH.
seriously, like a 3 pound sledge right on the red dots in the pic.
The vibrations are what release it, not direct force pounding it out.
Old Jul 4, 2018 | 05:55 PM
pirate4x4_camo
FTE Remembers
Old Jul 4, 2018 | 06:38 PM
gmammakn's Avatar
gmammakn
Tried that. With a sledge.
All day
Good work out
but no luck
Old Jul 4, 2018 | 08:16 PM
pirate4x4_camo
FTE Remembers
Heat is usually the next step on stuck things, I’ve never done it on a ball joint but hey, it’s gotta come out shomehow.
Heat heat bang bang....somethings gotta give
Old Jul 4, 2018 | 08:18 PM
Nicmike's Avatar
Nicmike
Veteran/Sheepdog
And enjoy that workout!
Old Jul 4, 2018 | 08:51 PM
gmammakn's Avatar
gmammakn
I should have just replaced the bearing.
Old Jul 5, 2018 | 08:21 AM
gmammakn's Avatar
gmammakn
Old Jul 5, 2018 | 08:25 AM
gmammakn's Avatar
gmammakn
I quit. Anyone want a 3 legged excursion?
My only real question is why me? Seriously.
Old Jul 5, 2018 | 09:06 AM
pirate4x4_camo
FTE Remembers
Time to get get destructive.
if it were my problem to solve I’d cut off the ball as close to the C as practacle . Then carefully find the center of where the threaded portion of the stud was and start drilling. Obviously you want the hole centered and straight because you might have to keep drilling to a substantial size before it will knock out.
this is a good time to own quality drill bits and punches because if you break cheapies in there the next step really gets ugly.
Hint.... before you drill a pilot hole start with a sharp center punch and then us 135* split point drill bits.
Old Jul 5, 2018 | 09:12 AM
JaySVX's Avatar
JaySVX
Sounds like you just need a bigger hammer. We've all been there with similar frustrations and think all hope is lost. Just have to push through. I spent 2 days getting my turbo lined up, it was a nightmare and it just wouldn't go no matter what I did. But eventually I got it, and it felt damned good.
Old Jul 5, 2018 | 09:24 AM
EXSwap's Avatar
EXSwap
I'd agree with drilling it out, but that's a tough process. It may be all you are able to do. But, what did you heat it with? Propane torch isn't enough, Map Gas MIGHT get you there, but there really is no substitute for oxy/acetylene. I'd heat it real good (cherry red) all around and take a big drift and a sledge to the top and drive it out. The downside is you're heating the metal pretty good on some important drivetrain parts. I can't tell from the pic, but is the top mushroomed out? If so, I'd say drilling is your ONLY option.
Old Jul 5, 2018 | 09:53 AM
rock2610d's Avatar
rock2610d
Take it to a machine shop. For a few dollars they will press the one out of c arm.
Rent a free ball joint removal tool from a parts store for the other one. Hint that's how the whole thing should have been removed.
Old Jul 5, 2018 | 10:01 AM
CanyonRider's Avatar
CanyonRider
Another option is to cut the bottom of the ball joint off and try driving the camber sleeve up (with the BJ stud still in it). Up to this point you've been trying to drive the stud down out of the camber sleeve - clearly that has been a no-go.
Good luck,
CR
Old Jul 5, 2018 | 10:13 AM
gmammakn's Avatar
gmammakn
Wow thanks for all the advice. No the top is not mushroomed out. It is cut even with the washer. And there is room around it because the PB blaster goes around the remaining pieces.
I have a press and a ball joint press, but coins not get it on with the wheel carrier in place
I have ave it on now. And every time I walk by I tighten it a little.
And im really stick because I can’t figure out how to get a wheel on to get it to the shop.
I don’t have oxyacetylene but I will go get map gas.
Anyone near akron and want to help with a front axle swap?
