Transit Connect 2010+ Ford Transit Connect
Front bumper cover removal
Old 03-01-2018, 07:27 PM
JTB321's Avatar
JTB321
JTB321 is offline
Hi all, I’m actually a member in the 1948-52 Truck forum but my daily driver needs some love also!! An unfortunate self inflicted ‘bump’ means i need to replace the upper and lower front bumper covers on my 2017 Connect Titanium. Anyone have a link or description of the bumper removal sequence and a good source of replacement parts? I’ve done similar jobs on my Jeep GC so I’mm ok delving in but a bit of guidance would be appreciated. No photos to post, still hurts too look at it
Thanks, John
Old 03-05-2018, 10:10 AM
EvanBly's Avatar
EvanBly
EvanBly is offline
John;
I see that no one has responded. You may be a first scout on this particular procedure. I'm guessing that you will have to go through a dealer for the parts. If so, it may be the case that the parts department folks can help out relative to the process involved. If nothing else, a parts manual might give you a clear idea of what you'll face in the surgery. You might also be able to find the parts in a junk yard. In any event, I will be interested in how you work this out. Good luck.
As an aside, I recently finished up a 10 year restoration of a 53 Ford pickup. One day a tourist from Norway happened to see the truck, fell in love and ended up buying it. Like Ford in general, the truck is a world traveler.
Old 05-01-2018, 02:00 PM
Kirked's Avatar
Kirked
Kirked is offline
John,
Curious to see if you ever figured out how to remove the bumper? I am very interested. There is a bracket behind the grill that I would like to mount something to.
Let me know what you found out? I assume it is a pretty involved process.
Old 05-01-2018, 02:33 PM
JTB321's Avatar
JTB321
JTB321 is offline
I managed to get the bumper off and back on but not straight forward. I need to do it again to figure out why the lower bumper cover is not seating correctly on the clips. I’ll take some photos this time and post them. Probably this weekend.
john
Old 06-15-2018, 11:08 PM
Fifty150's Avatar
Fifty150
Fifty150 is offline
Just from being under my own Transit Connect to do oil changes, it looks like the only thing holding the van together is a handful of pop rivets. It appears that if you raise the vehicle, remove the front wheels, remove the lower skid plate like you're performing an oil change, then the bumper and wheel wells will come off next, all by way of removing plastic pop rivets.
yitzy
Aerostar
08-27-2011 02:46 AM
cooky
05-22-2006 11:19 AM
BlueOvalfan85
Appearance & Dress-Up
06-05-2005 10:50 PM
jdog0411
01-04-2005 02:22 AM
doodaa
Aftermarket Products
08-06-2002 07:27 PM
Quick Reply: Front bumper cover removal
