need to change brakes and rotors, I want to upgrade to drilled and slotted rotors. I have looked at new rotors online and have only been able to find rotors with the dually extension cast to the rotor, since my truck has a removable extension.
Can a rotor from a SRW rotor be used and extension but back on?
Powerstop Z36 are made for towing and they are drill (with beveled edges) and slotted and have great results/reviews.
I've got them on mine and love them.
I've been told a lot of things and many have been wrong.
Are you sure the extension hub is cast with the rotor?
The rotors I got from Rock Auto included the hub assembly, but it wasn’t cast as part of the rotor. It is a two piece assembly, pressed together at the suppliers assembly plant, probably to control runout.
If their like the ones on my 1996 F250, they are two-piece, but not pressed at the supplier. You can knock the lug bolts out with a BFH (put the lug nuts on backwards so you can hit the flat side without damaging the threads). It shouldn't take much of a hit.
The two pieces are "snug fit", not press-fit. Put a chisel or similar at the joint and "persuade it" into the joint with the BFH. They should come apart fairly easily.
Thanks for the info on the slotted/drilled rotors,will read this thoroughly before purchasing.
my real question is, will a SRW front disc brake rotor work on a dually truck with the OE bolt on extension.
I do not like the looks of the one piece rotor and extension
Thanks
NO, a single wheel rotor won't fit. First reason, the bolt pattern is different, and second, I believe they are a different size as well. But I'm not sure on that...
The answer is no you can't use 2wd rotors on a 4x4 because the hub extension will not come off. What I did on my 2000 DRW and now on my 2013 DRW is to upgrade to Prefomance Friction Carbon Metalic pads on standard rotors, they have excellent stopping power and fad resistance with no noise when pulling heavy like I do.
