Front brake rotors
2001 F350 4X4 crew cab DRW 7.3
need to change brakes and rotors, I want to upgrade to drilled and slotted rotors. I have looked at new rotors online and have only been able to find rotors with the dually extension cast to the rotor, since my truck has a removable extension. Can a rotor from a SRW rotor be used and extension but back on? |
I have no idea on the extension. I've been told that if you tow you don't want drilled rotors as they tend to crack.
Powerstop Z36 are made for towing and they are drill (with beveled edges) and slotted and have great results/reviews.
I've got them on mine and love them. I've been told a lot of things and many have been wrong. |
I've seen pictures of drilled rotors with cracks radiating out from the holes. It does happen. A quick Google search shows plenty of these. Here's an article on it: Performance Brake Blog - Why Drilled Brake Rotors Crack | Cquence.net. The beveled edges should help.
EBC doesn't provide any cross drilled rotors: https://ebcbrakes.com/articles/dange...rilled-rotors/ |
Thanks for the info on the slotted/drilled rotors,will read this thoroughly before purchasing.
my real question is, will a SRW front disc brake rotor work on a dually truck with the OE bolt on extension. I do not like the looks of the one piece rotor and extension Thanks |
Are you sure the extension hub is cast with the rotor? The rotors I got from Rock Auto included the hub assembly, but it wasn’t cast as part of the rotor. It is a two piece assembly, pressed together at the suppliers assembly plant, probably to control runout. |
Originally Posted by finn
(Post 18058475)
Are you sure the extension hub is cast with the rotor? The rotors I got from Rock Auto included the hub assembly, but it wasn’t cast as part of the rotor. It is a two piece assembly, pressed together at the suppliers assembly plant, probably to control runout. The two pieces are "snug fit", not press-fit. Put a chisel or similar at the joint and "persuade it" into the joint with the BFH. They should come apart fairly easily. If yours are NOT like mine, well - then nevermind :) |
Well, thanks for all the responses. FYI I bought a rotor from Carquest,# YH145274P fit perfectly, for a SRW
(Post 18056093)
need to change brakes and rotors, I want to upgrade to drilled and slotted rotors. I have looked at new rotors online and have only been able to find rotors with the dually extension cast to the rotor, since my truck has a removable extension. Can a rotor from a SRW rotor be used and extension but back on? Denny |
@351Cleveland C4 , outer bolt flange is rotated 1/2 bolt hole from inner,no difference in bolt circle/dia. far as I know truck is OEM
Go here and order the proper parts, this is also where I bought my Preformace Friction pads
http://www.autoanything.com/brakes/61A2854A0A0.aspx Denny |
Dually trucks run 8x200mm. Single wheel is 8x170mm. There is a difference.
If you look further down the link you can choose the 4x4 option.
Denny |
