Sponsored by: Real Truck
2004 F250 electrical issues
Old Jun 25, 2018 | 04:49 PM
Asmith30909's Avatar
Asmith30909
I have a 2004 F250 6.0 4x4 that I cannot get any dash gauges to work although the dash lights work and the alternator is showing not working. I have replaced the alternator and tested it it works fine but when installed it reads no voltage to the truck. Can't figure it out
Old Jun 25, 2018 | 07:32 PM
texastech_diesel's Avatar
texastech_diesel
Token Redneck
Crank no start, or is it running?
There's a red 6ga wire coming off a stud the driver's side battery terminal, is that connection clean and right?
Old Jun 25, 2018 | 08:07 PM
Asmith30909
I'll check in the morning. Hopefully it is that simply ty in advance if it is
Old Jun 25, 2018 | 08:08 PM
Asmith30909
and it starts and runs fine just no Guage action and the alternator reads 0 output when running at the back of the altenator
Old Jun 25, 2018 | 08:29 PM
TooManyToys.'s Avatar
TooManyToys.
The dash gauge battery light turns on the alternator. Bad gauge package, no alternator engagement.
Old Jun 26, 2018 | 07:30 AM
projectSHO89's Avatar
projectSHO89
Which wire?
Oops, had to edit. Mis-read as an F150.... Disregard if you happened to see the incorrect information that was up for a couple of minutes...
Did you check fuse F45? It supplies both the cluster and the TOW/HAUL switch with power. A recurring problem on F-series was a chafed wiring harness at the entry to the column-mounted shift lever that causes that fuse to blow and takes out the cluster's electronics. As Jack mentioned - no cluster operation, no charging.
Old Jun 26, 2018 | 01:07 PM
CircuitBoardMedics's Avatar
CircuitBoardMedics
We are sorry to hear you are having issues. TooManyToys is right that the circuit for the alternator on those trucks does run through the instrument cluster, so if you have a faulty cluster then it could be causing issues with your alternator. We do offer a rebuild on those clusters which you can find at the following link: https://circuitboardmedics.com/2002-...luster-repair/ or feel free to give us a call at 800-547-2049. We can specifically test for the alternator issues before we do the repair to make sure we can replicate your problems. Please let us know if you have any other questions or if there is anything else we can help you with.
ck22
Jul 4, 2015 07:52 AM
Joe_fummins
Jan 20, 2014 10:54 AM
maximumd93
Mar 11, 2013 09:52 AM
wingnutt2420
Sep 30, 2010 05:23 PM
mfgdesigner
1997 - 2003 F150
Sep 10, 2005 10:34 PM
