IP question
I have a general idea of how the IP works but can’t think of what internally in the IP would cause this. My guess is something to do with the internal Governer or governor linkage but not sure. any ideas? Comming back from Amarillo Friday, going up a couple big hills, I was loosing speed (75 down to 68mph) with WOT. Hills used to not bother this thing at all with a light to no load.
7.3 with sidewinder and E4OD with 4:10s in the rear.
The answer is YES. It's located in the Oklahoma "Pan handle" which was called "No Man's Land" until 1890 and one of the the things it's known for historically is big dust storms.
Oklahoma Historical Society - Guymon
The following page has two photos of two different huge dust storms approaching Guymon in the 1930's:
Local History ? Guymon
There are probably a lot of dusty gravel and dirt roads in that area.
Where I live in Western Washington State, we don't have dust storms, just long months of drizzly rain and the air seems clean all year long except that there is a lot of green pollen falling from the trees and from plants during the Spring & Summer months. It sticks on vehicles as if it has rooted itself there, even on the glass and requires some scrubbing to get it off. I would not be surprised at all if it can plug air filters over time.
I HAD THE EXACT SAME SYMPTOMS AS YOURS in a full size Jeep Cherokee, 1983 inline 6 258 cid that I bought from a car dealer and the vehicle was only 4 years old! No one, none of the mechanics they had or consulted with could figure out what was wrong with it and they had installed a completely rebuilt engine! They couldn't sell it because of THAT. I bought it anyway because I WANTED AND NEEDED THAT 4WD VEHICLE. About 2 weeks later the throttle cable completely failed to operate the throttle. What had been wrong with it in the first place was that the cable housing around the wire cable had SPLIT. You couldn't see it by just looking under the hood but when the throttle was opened with the accelerator pedal the inner cable was pulled out of it's housing though a split in the side of the housing and in effect this was like having a LOT of slack in the cable. It was only opening the throttle HALF WAY, when the accelerator pedal was pushed to the floor.
I was SURE HAPPY! For a $16.00 NEW throttle cable I had a 4 year old full size Jeep Cherokee (the last year those were made 1983) with all of the heavy duty options available from the factory and with a brand new engine! It cost me aout $1500 max in 1987 and it was one of the best vehicles I have ever owned. I put a LOT of miles on that truck, over 250k miles and in my opinion it was A TRUCK. It did some hard work for me in very remote areas and never failed me. I did burn up one torque convertor probably from hauling heavy loads up very steep mining roads out in the mountains but it failed in the city and I had a spare transmission and engine, so I just replaced the TC, went through the transfer case - (only needed new seals - maybe a new bearing but the chain was still fine) and replaced a broken transmission mount an it was ready to work out in the wild again. Later I re-did the manual lockout WARN hubs. That was sure a GOOD VEHICLE!
Anyway, YEAH, could be a bad throttle cable! You describe the EXACT SAME symptoms of what my experience was with a bad throttle cable.
Let us know what it turns out to be!
