Mileage drop off
Old Jun 24, 2018 | 11:48 AM
IHateCommieCars's Avatar
IHateCommieCars
Mileage drop off
Y'all know me, I'm prolly delusional, but is there anything that could make my gas mileage plummet? Truck seems to be running fine, just using a lot more fuel. I'm gonna go drill into my reciepts and confirm how much fuel I bought on this trip, but watching the gauge it sure seemed to be sucking my tank.
Old Jun 24, 2018 | 01:06 PM
packagerjr's Avatar
packagerjr
My understanding is you could be burning more (injector issue), have it leaking into the oil system, leaking into the coolant system, or have an external leak.
Old Jun 24, 2018 | 01:56 PM
78fordman's Avatar
78fordman
Any codes set? Could be a bunch of things. If not codes are set i would do some sensor cleaning and a tune up. New fuel/oil and air filters, clean the ebp sensor/tube, map sensor/tube, IAT2 sensor and the MAF sensor. Check the ficm voltage at cold start and see what the max boost you can acheive with stock tuning, it should be close to 28 psi. Last I would watch icp desired and icp actual and see if the hpo system can make what the pcm wants.
Old Jun 24, 2018 | 02:15 PM
OneCylinder's Avatar
OneCylinder
Years ago I killed every mosquito between the Texas state line and the Colorado state line on US 64 in New Mexico. Not to mention I degreased the underside of the truck and the 5er. Turns out the fuel line to the upper filter housing was loose. Probably the last Ford tech to work on it had wimpy arms. Luckily I had the correct wrench with me, tightend it up and I was on my way.
Check the fuel line connections.
Old Jun 25, 2018 | 03:46 AM
Yahiko's Avatar
Yahiko
Could also be as simple as a dirty air filter.
Old Jun 25, 2018 | 01:57 PM
Rusty Axlerod's Avatar
Rusty Axlerod
Or a brake sticking.
JT Smitty
Aug 29, 2012 06:14 PM
yeldarb82
13
Sep 16, 2009 06:56 AM
edub32
25
Feb 20, 2009 05:51 PM
xc007
Jan 24, 2006 09:20 PM
jadel
Feb 14, 2005 07:14 PM
