I acquired a new-to-me project! This was my uncles for many years... and now I will keep it in the family and continue his work. It has been in storage for 18 years and needs a lot of maintenance. The brakes are shot and the engine has coolant in one cylinder. I will post updated photos as things progress.... but needless to say that I am ready to start.
Reason: Change the Tital
Hehe... it took me a little time to remember that I wrote "Gods Country" on where I am from. Yes, I am from Oklahoma! I appreciate the welcome Abe. You guys can call me Adam. I look forward to learning from you guys and all of the expertise in this forum!
This truck has set for 18 years. My plan was to first look at the motor and determine how extensive the work would be to get it in shape, but my priorities changed when we went to unload the truck off of the trailer. It seems that when I hit the brakes, the front wheel cylinders locked up and wont release!!! Had a heck of a time pushing the Ford into the shop and onto the lift!!! But now shes in the right spot and I have ordered the front disk upgrade, a firewall mounted booster & master cylinder, and other hardware to modernize the entire system.
The motor will have to wait until another time.
Thank you Adam, your`s looks every bit as nice! Mine is still flat head powered, what`s your`s?
My uncle installed a 350 Buick in it many years ago. It has been in storage so long that the engine has some mechanical issues.... so I have some decisions to make. I will keep you posted.
Looks good, what brand of kit did you use? I really like those wheels, nice ones are getting hard to find now.
The brake kit is from CPP through MidFifty.com. Thanks.... my uncle said that the wheels were bought from a Ford dealer many years ago. I assume that they are factory Ford wheels... but I am not sure.
Why did you have the twist tie on that loose nut..?
Hehe... that is a good question. Each wheel has a locking lug nut, and what you are seeing is actually a steel cable attached to the "key" that was sitting on the locking lug right after I used the impact to remove it. The locking lug is still partially threaded on the stud.
