Explorer 4wd problem
Old Sep 21, 2003 | 08:28 AM
explorer97xlt's Avatar
explorer97xlt
Question Explorer 4wd problem
Hi all,
I'm new to this forum and hope you can help me. I have a '97 Explorer XLT 4WD with SOHC engine. It has 90,000 miles on it. It just started displaying a blinking 4WD high and 4WD low warning light. It will display the lights 6 times every 2 minutes.
The next day after first receiving those lights - I ran into a problem where the front left wheel appears to be sticking while driving forward. At times it completely binds when taking a sharpe left turn, but doesn't show the same problem on a right turn (yet).
To make matters worse the first time it appeared to bind was as I was driving out of the dealers lot after I had it appraised since I am thinking about buying a new vehicle. How's that for timing? I am looking for some potential inexpensive fixes since I don't want to put a lot of money into a car I'd be trading in.
Thanks!
Old Sep 21, 2003 | 10:48 AM
Bashman's Avatar
Bashman
The 6 flashes is the code for bad speed sensors on your transfer case. Some easy things you can try are:
1. Check fuse 26, make sure it's not blown.
2. Disconnect the battery for five minutes to reset your computer.
3. Start your truck, put it in neutral and with your foot on the brake cycle your switch from 4hi then 4lo then back to auto, this will sometimes clear it.
4. Pull and clean your speed sensors.
If these don't work you could be looking at having to replace the speed sensors, cleaning or changing the t-case shift motor or replacing the GEM.
Old Sep 21, 2003 | 01:43 PM
explorer97xlt
Thanks Bashman! That seems to have done the trick!
For others, what I did is check the fuse - it was ok. I disconnected the battery and that did clear the code, but the problem remained. I then cycled the switch through 4hi to 4lo and back. That seems to have resolved the problem at least for now.
Thanks again!
guessrow
2004 - 2008 F150
Jul 26, 2014 10:19 PM
havasulew
Jun 10, 2011 07:56 AM
dnichols47
Offroad & 4x4
Jan 7, 2004 09:13 PM
nosbor
19
Dec 11, 2003 09:50 AM
