Help with Weak brakes
Old Jun 21, 2018 | 01:48 PM
Logan Ketchum's Avatar
Logan Ketchum
My brakes in my 1975 Ford f100 are very weak and will build some pressure but won’t stop very well, the pedal will go to the floor only if pressure is applied slowly. Their are disk in the front and drum in the back. Can anyone help me find out what the problem is? Thanks!
Old Jun 21, 2018 | 02:02 PM
FuzzFace2's Avatar
FuzzFace2
That is a sign of a bad master cylinder .
Get a new one, bench bleed it before install and you should be good.
Now would also be a good time to check the whole system over. Metal & rubber lines as at the wheels.
Dave - - - -
Holehawgg
Jan 6, 2015 01:17 PM
for46016
1978 - 1996 Big Bronco
Apr 1, 2009 09:33 PM
boogity24
Jun 27, 2004 09:48 AM
plitz.....
Apr 11, 2004 01:18 PM
