Sponsored by: Real Truck
hill descent control
Old Jun 21, 2018 | 01:16 PM
96_F250_Deezal's Avatar
96_F250_Deezal
Question hill descent control
looking to enable hill descent control on my 2011 F350. from what I have read, it seems to be as easy as adding the switch on the dash and enabling the feature with IDS or ForScan.
The problem I am running into is when I enable HDC with the ForScan tool, it automatically enables trailer brake control, which is not installed on this truck.
has anybody else done this?
Old Jun 22, 2018 | 05:59 PM
seville009's Avatar
seville009
Don’t have an answer, but if you haven’t actually added the hdc switch yet, maybe that’s confusing Forscan. Might work once the switch is installed.
For what it’s worth, you can pretty much do what hdc does by either using the tow/haul mode, or using the manual shift mode if you have it. I have hdc on my 2011, but have never used it.
Old Jun 22, 2018 | 09:29 PM
DieselBeast01's Avatar
DieselBeast01
The only time hill decent control works on mine is when I have a trailer with brakes connected. anyone know if it is supposed to work all the time?
Old Jun 23, 2018 | 03:27 AM
seville009's Avatar
seville009
should work with no trailer connected. While I’ve never used mine intentionally, I have accidentally turned it on when I was aiming for the traction control button, which is right next to it.
Old Jun 24, 2018 | 08:42 PM
DieselBeast01
So that is what that other button is! Didn't know what it was. Guess I just don't ever have it on.
Old Jun 25, 2018 | 09:37 AM
puppyf250's Avatar
puppyf250
Hill descent control, on my 2014 F-150, will work with no trailer attached. But, is designed to not turn on over, I believe 20 miles per hour. Once turned on, it works very well to restrict down hill speed.
Old Jul 1, 2018 | 11:01 PM
96_F250_Deezal
found a good deal on a new trailer brake controller, so I added both to the truck over the weekend. installed new HDC switch on the dash, installed the trailer brake controller. I used the ForScan tool and enabled the TBC in the ABS module, this automatically enabled the HDC. I also had to enable the TBC in the instrument panel to allow the settings to show up in the setup menu.
Old Jul 2, 2018 | 12:07 AM
96_F250_Deezal
Old Jul 2, 2018 | 08:01 AM
5851a's Avatar
5851a
Was the descent switch individual or did it come with another traction control switch?
Old Jul 2, 2018 | 10:37 AM
96_F250_Deezal
it comes as the entire switch assembly, motorcraft SW6777. I got mine off Rockauto.
Old Jul 5, 2018 | 08:31 AM
5851a's Avatar
5851a
Thanks for that.
Old Dec 17, 2023 | 05:31 PM
svtsnakebyte's Avatar
svtsnakebyte
4wd Low
hill descent control Forscan
I know this is an old post but I would like to add hill descent control to my 2011 F250 with Forscan and a new switch. Does anyone know the module address number and hex that has to be changed?
Old Dec 20, 2023 | 07:44 PM
96_F250_Deezal
read here - https://docs.google.com/spreadsheets...#gid=540322413
Old Oct 3, 2025 | 01:20 PM
stever1000's Avatar
stever1000
Is there a switch package that has a third button? or are they only optioned with hill descent and traction control?
Old Oct 3, 2025 | 03:52 PM
Euroman's Avatar
Euroman
my 2015 just has the 2 buttons, like in the picture.
DDT11
Aug 31, 2017 07:15 PM
Beachums
2015 - 2020 F150
29
Aug 29, 2017 10:02 PM
Xwild
Aug 15, 2016 08:28 AM
H2oSprayer
Jul 10, 2012 09:02 AM
jbhford
2004 - 2008 F150
Apr 15, 2008 08:13 PM
