1966 f100 heater hose connections
Old 06-20-2018, 06:06 PM
rsh1966's Avatar
rsh1966
rsh1966 is offline
I searched but did not find any heater hose connections.
I have a 390 2bl and would be most appreciative of a pic of the heater hose connections. I will look at my manual tomorrow but I like to see a pic of the actual motor and the hoses connected.
Thanks for taking your time to do this.
rsh1966
Old 06-20-2018, 08:27 PM
Sortofa65's Avatar
Sortofa65
Sortofa65 is offline
Here you go 390 in a 65
Old 06-20-2018, 09:04 PM
Jolly Roger Joe's Avatar
Jolly Roger Joe
Jolly Roger Joe is offline
Looks like they connect like on my 352.
Old 06-21-2018, 06:58 AM
rsh1966's Avatar
rsh1966
rsh1966 is offline
Thanks guys for the pics. This is just what I needed.
Thanks again for your time.
rsh1966
Old 06-21-2018, 09:35 AM
66with352's Avatar
66with352
66with352 is offline
I noticed the heater control valve is on the outside hose in Sortof's pic and its on the inside hose in Jolly's pic. Does it make a difference which hose it's in line with. Does it even make a difference which hose goes to the inside or outside connection on the heater core?? Just curious
Old 06-21-2018, 10:44 AM
AZSCAWPION's Avatar
AZSCAWPION
AZSCAWPION is offline
The short answer is no. All you are doing is circulating coolant through the heater core. As long as it's connected, the heater works.
Here is how mine is routed, which I believe is as it was from the factory. There are some that will disagree.
Old 06-21-2018, 11:49 AM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
C3UZ-18495-A .. Cable Controlled Heater Water Valve (Motorcraft YG-133).
This valve is spliced into the inlet to heater core heater hose. Pic of valve in post #6 shows this hose.
1963/67 E100 // 1965/66 F100/1100 with deluxe fresh air heater // 1967/72 F100/750 // 1969/74 E100/300 with factory A/C
Old 06-22-2018, 08:54 AM
rsh1966's Avatar
rsh1966
rsh1966 is offline
After I got out to the shop I looked at the pics that I printed out and saw the same thing that "66 With 352" saw. The hoses were connected two different ways. However I would thing that it would work either way. You are just controlling the water circulation. I did go to my Shop Manual Vol. 3/4, page16-2 shows the hose connections. This shows the cut off on the inlet hose coming from the manifold and connected to the left (as setting in the cab)side of the heater. The outlet is the coming from the water pump.
Thanks for all the comments and pictures. I really like to see pictures when I am working on things.
rsh1966
Old 06-22-2018, 11:15 PM
shawnmk's Avatar
shawnmk
shawnmk is offline
So this post got me curious about my 66 and it's heater. I looked in the engine bay and didn't see any valve like everyone else has posted about. Starting at the dash control, I followed the cable under the dash to a heater unit of some sort with the cable ending at a mechanical switch/valve of some sort. Was this something aftermarket? An upgrade or just different maybe?
Old 06-23-2018, 12:05 AM
Boss9F100's Avatar
Boss9F100
Boss9F100 is offline
The valve was only standard on the Deluxe Heater. Since yours is the Standard /Manual heater it did not have the valve. There was a manual valve avail.
The valve should go to the inboard side of heater core then to water pump. Outboard goes to fitting on intake.
Old 06-23-2018, 12:10 AM
Boss9F100's Avatar
Boss9F100
as long as valve is on water pump side its fine. But the water pump side hose from factory went to the inboard side on core.
Old 06-23-2018, 06:30 AM
Jolly Roger Joe
So are you saying mine is correct as the factory installed them?
Old 06-23-2018, 11:06 AM
NumberDummy
C5TZ-18495-A .. Manually Operated Heater Water Shut-Off Valve-Use with Economy Fresh Air heater (Motorcraft YG-130) / Obsolete
1965/66 F100/1100 // 1965/67 N/NT500/100 // 1967 F500/750 // 1967/69 F800.
GREEN SALES CO. in Cincinnati OH has 5 = 800-543-4959.
Old 06-25-2018, 01:50 AM
Boss9F100's Avatar
Boss9F100
Gotta be careful when green sales says they have them. when it shows you just may find a made in china part. Typical of them to forget to mention that.
I do have a NOS one still in FoMoCo box
Old 06-25-2018, 01:52 AM
Boss9F100's Avatar
Boss9F100
Correct Yes
mrpotatohead
05-27-2018 05:52 AM
benbuilder
04-13-2018 02:40 PM
Cbronwen16
1999 to 2016 Super Duty
09-24-2010 02:31 PM
jamesmcowan
01-02-2010 07:17 PM
tndiesel
24
07-23-2007 12:03 PM
Quick Reply: 1966 f100 heater hose connections
