Killem Biocide
Old Jun 18, 2018 | 11:30 PM
CO Wapiti's Avatar
CO Wapiti
Killem Biocide
I purchased a 60 gallon Transfer Flow tank and they recommend this product. Anyone have any experience with diesel fuel growing anything funky and causing a problem? I purchased this product and they have a recommended dose as a maintainer but I haven’t used it yet.
Old Jun 18, 2018 | 11:50 PM
bushpilot's Avatar
bushpilot
man in 15 years ownership of my 2004 with 90g of fuel I NEVER used an additive or had a problem w/ contamination - and the truck sat for months fairly often....it even sat for over a year w/out starting or moving and I never had any issue.
Old Jun 19, 2018 | 05:57 AM
zeroo's Avatar
zeroo
I have. It makes a slime on your filters. I will use it in my farm tank once in a wile just to make sure.
Old Jun 19, 2018 | 08:38 AM
HRTKD's Avatar
HRTKD
The Motorcraft PM-22a also contains some form of biocide as I recall.
Old Jun 19, 2018 | 08:41 AM
troverman's Avatar
troverman
I have a 60 gallon RDS tank in my truck bed...no issues so far even with leaving a half-tank of diesel for a few months before using it. But it might not be a bad idea, so long as it won't hurt the Powerstroke's injection pump.
Old Jun 19, 2018 | 10:28 AM
wrvond's Avatar
wrvond
The answer is "yes, diesel fuel has the potential to grow algae." However, some environments are more conducive to this growth than others. If the company you are dealing with is local, and if they included a statement along the lines of: "many customers in this area have experienced algal growth in their fuel, so we recommend blah, blah, blah.", I'd be more likely to use some kind of biocide (probably PM-22a).
Old Jun 19, 2018 | 11:08 AM
wb6anp's Avatar
wb6anp
Same type of stuff is added to jet fuel to prevent algae growth in tanks, we used to have to addid th i in maually from a spray can, now most is premixed.
Old Jun 19, 2018 | 11:28 AM
pogeybaitF350's Avatar
pogeybaitF350
I have a little over 350 gals in a tank for a genset that sits in a shed here in the Springs. Have never had an issue, and have only treated it with the Power Service anti gel additive. I do use some for a tractor, occasionally the truck, and add to it every now and then. Neighbor has the same set up and no issues. .
Old Jun 19, 2018 | 11:36 AM
Robb81's Avatar
Robb81
If you are going to use the fuel in the auxiliary tank in less than 90 days I wouldn't worry about any biocide or stabilizer. If you are planning on storing the fuel for months then I would look into stabilizer, biocide, and running it through at least a 10 micron water absorbing filter before putting it in any modern high pressure diesel engine.
Old Jun 19, 2018 | 01:12 PM
CO Wapiti's Avatar
CO Wapiti
I didn't know the motorcraft PM -22a had a biocide included in it (even though I can't find it stated in a websearch). I use the PM22-a with every fill up and the PM23 in the winter so I guess I'll use the Killem biocide in my tractor and stored diesel fuel that I keep, which both can sit for 6 to 8 months without using.
I do remember taking apart a gas carberator in a snow thrower at work that was sitting for a couple of years and the internals were coated with a green slimy algea.
I believe in taking preemtive measures for anything that can go wrong within reason and using an additive every now and then is pretty darn easy.
Old Jun 19, 2018 | 04:06 PM
Tedster9's Avatar
Tedster9
PRIST, though I recall it was both a deicer and a biocide that was added. Yeah they take that **** seriously. The first thing "they" do whenever the VIP very special folks show up is commandeer the fuel trucks. "Get out".
Old Jun 19, 2018 | 05:06 PM
wb6anp's Avatar
wb6anp
Yuo that's the stuff, forgot the name been out of ground/fuel service for a few years moved over to the maintenance side of things about 25 years ago, now retired from Corporate jet maintenance.
Baldicon
Jul 31, 2018 04:10 PM
Flyct
Jun 12, 2018 11:35 AM
MrJoeJitsue
Feb 18, 2011 11:31 AM
crossf-150
Jul 2, 2010 04:30 AM
boxcar44
Jan 22, 2007 06:10 PM
