NEW PROPORTIONING VALVE
Old Jun 17, 2018 | 09:48 AM
alans77crew's Avatar
alans77crew
I have a 79 f 250 sc that my son and I are putting back together for him,we need a proportioning valve. Anyone know where I can get one with the correct size fittings,All I can find is for the 1/2 tons and they have the wrong size fittings in them. Thanks for any help!!!!
Old Jun 17, 2018 | 12:54 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by alans77crew
I have a 79 F250 Super Cab (2WD?) that my son and I are putting back together for him,we need a proportioning valve. Anyone know where I can get one with the correct size fittings.
D4TZ-2B257-A .. Brake Pressure Differential Valve-Use with disc brakes / Marked: D4TA-2B328-A1A or A2A or D5TA-2B328-C1A or C2A / Obsolete
1974/79 F250 2WD with 6900, 7500 & 8100 lbs. GVWR // 1974/78 F350 // 1979 F350 2WD // 1975/79 E250/350.
If your F250 has 4WD, it uses the same valve as 1975/79 F100/150, E100/150 & 1978/79 Bronco.
Old Jun 20, 2018 | 08:36 PM
VitaminC's Avatar
VitaminC
Another option is to get a Wilwood universal valve kit.
Old Jun 20, 2018 | 11:35 PM
jakeharp's Avatar
jakeharp
https://www.summitracing.com/search?...ioning%20valve
One of those should be a match ?
Old Jun 21, 2018 | 07:04 AM
alans77crew
Sorry guys It is a 4x4 and thanks for you answers, I was looking at my truck for the comparison but I have a 60 up front with what appears to have larger brakes in it than than his 44. Is that correct? Caliper looks much larger. Number Dummy a special thanks to you your knowledge and resources are unmatched! I used to have a good friend much like you but alas we lost him to a brain aneurysm a few years ago. RIP Mick Anderson.
Old Jun 21, 2018 | 09:16 AM
ultraranger's Avatar
ultraranger
The standard inverted flare nut size for 3/16" tubing is 3/8"-24. You can get these individually from any parts store. Ford also used specialty sized 7/16"-24, 1/2"-20 and 9/16"-18 inverted flare nuts for 3/16" diameter tubing. You can get these specialty sized flare nuts brand new from Classic Tube.
1. 7/16"-24 flare nut. Tube Nut 7/16-24 - SAE - Red
2. 1/2"-20 flare nut. Search results for: 'St8007'
3. 9/16"-18 flare nut. Search results for: 'st8010'
Old Jun 21, 2018 | 09:31 AM
NumberDummy
All 1976/79 F250 4WD's and 1979 F350 4WD's have dual piston caliper disc brakes.
D5TZ-2B257-B .. Brake Pressure Differential Valve / Marked: D5TA-2B524-FA or FB / Obsolete
1975/79 F100/150 2WD/4WD / 1975/79 F250 2WD with single piston caliper disc brakes / 1975/79 E100/150 / 1976/79 F250 4WD & Bronco / 1979 F350 4WD
No Ford dealer or obsolete parts vendor has any.
Old Jun 21, 2018 | 01:00 PM
jakeharp's Avatar
jakeharp
You will find that its one valve that many distributors place their name on, but for the most part, they are identical for your make and model. Price is all over the map, but its the same piece...
Old Jun 21, 2018 | 09:48 PM
somethingclever's Avatar
somethingclever
D44 and d60 same calipers in f250 or f350
Old Jun 23, 2018 | 09:48 AM
alans77crew
Much thanks to everyone! Ordered one,Jake Harp you are most definitely correct! I got to looking at them and there all the same except price they ranged from 48.00 to 120.00 crazy. But again thanks for all you Help I do appreciate it
Jim Lovell
Jun 8, 2019 10:20 AM
captainwoot
Jan 8, 2018 06:44 PM
belshe92
Jun 2, 2016 11:51 PM
elkarcher1716
Dec 8, 2013 04:54 PM
79 F100 Stepside
23
Aug 31, 2010 08:03 PM
