1978 - 1996 Big Bronco
Engine stalling
Old Jul 9, 2018 | 10:21 PM
  #31
McLeod's Avatar
McLeod
I'd get rid of it, but in the least, that is an odd place to put it- under the truck?
Old Jul 10, 2018 | 09:18 AM
  #32
rvarc's Avatar
rvarc
Im still stuck with the issue of "why is it there".
For oow, I'm going to run the wires to my dash and put a switch there so i van cut it ofg on the highway.
In the mean time, try to figure out what is going on.
Old Mar 7, 2019 | 08:19 PM
  #33
BigRedFishDad's Avatar
BigRedFishDad
I know this is a little old but this is the EXACT issue my son is having with his 1988 Bronco. He recently rebuilt the transmission got it installed. Was able to drive it around the neighborhood and test drive on the highway a few times. Said it was vibrating quite a bit but I really think that was tires he had 3 of the original previous owner tires probably about 10 years old and then one oversized tire on the passenger side front. We finally found some used tires all the same size and after sitting about two months we get the EXACT behavior as you. Reverse he can drive around the yard all day puts it in drive and it will die after about 10-15 seconds or if you give it gas it dies immediately. I am going to test the put it in 1st this weekend but he said he tried that and it works. So it sounds like the exact thing but there are no solenoids in the AOD and I don't understand what that switch you found does??
Old Jul 26, 2023 | 08:58 AM
  #34
briisbackn23's Avatar
briisbackn23
2nd Gear
94 f250 7.5l vacuum line diagram from resivoir
Red vacuum lines.. I need a map /diagram of where they go.. Can't seem to find one anywhere online
Need diagram/map of the vacuum hoses for a 94 ford f-250 with the 7.5l in it
Need to know where that line goes 🤔😑😡
Old Aug 4, 2023 | 09:02 AM
  #35
Redark1's Avatar
Redark1
you should find the other end of that hose inside the wiring loom next to the fender / firewall farther to the left in the pic. that's the vacuum hose for the recirc door.
PEG
1997 - 2003 F150
May 28, 2019 10:29 AM
772504x4
Mar 13, 2015 10:21 PM
Blue7.3
Australia Chapter
Sep 21, 2014 07:01 PM
96ford250
16
Dec 13, 2012 10:11 PM
cyborghunter
Jan 14, 2012 09:31 PM
