1978 - 1996 Big Bronco
Engine stalling
Old Jun 17, 2018 | 02:17 PM
rvarc's Avatar
rvarc
If you can tell if obd1 or 2 ill run get a code reader.
really appreciate your help with this.
Old Jun 17, 2018 | 02:26 PM
McLeod's Avatar
McLeod
Looks to be OBD1 mass air truck
I think it can be verified by reading that sticker on the hood.
Hopefully someone smarter than me comes along and guides you to a conclusion
The "other" thread I mentioned in post 2 had mentioned the mass air flow meter as the last area they delved into, which is where the electrical wiring in your intake tube is located.
Maybe cleaning it with air flow sensor spray cleaner will help. Just don't touch the internals with anything other than spray. Check your air filters while you are in there.
FYI:
you also are missing the part of your air box that picks up fresh air from the front of the hood. Unlikely it will affect performance, but it isn't as designed.
Old Jun 17, 2018 | 04:39 PM
rvarc's Avatar
rvarc
I did get a 157 code which is mafs low voltage. Took it off and sprayed it with intake cleaner but same problem. Guess I'll be replacing it.
Old Jun 17, 2018 | 04:58 PM
rvarc's Avatar
rvarc
Actually the 157 code went away . Problem didnt
Old Jun 17, 2018 | 07:22 PM
McLeod's Avatar
McLeod
reset the computer by disconnecting battery positive lead and touching the frame with it?
Old Jun 22, 2018 | 06:34 PM
rvarc's Avatar
rvarc
Put a new mass airflow sensor on today, no change
time to take it to a pro.
Old Jun 24, 2018 | 08:46 PM
rvarc's Avatar
rvarc
I'm wandering if it could be the torque converter lock up switch?
Old Jun 25, 2018 | 08:09 AM
rla2005's Avatar
rla2005
There is no "torque converter lockup switch".
Old Jun 25, 2018 | 01:10 PM
rvarc's Avatar
rvarc
Torque converter clutch solenoid. Had the name wrong.
Old Jun 25, 2018 | 02:08 PM
McLeod's Avatar
McLeod
If you search there are many people who have *added* a switch to control TC lock up.
Manual-Off-Automatic
Some do it for testing reasons
others just because....
Read up on it to see if it would help you or not
Old Jun 25, 2018 | 02:55 PM
rvarc's Avatar
rvarc
Will do. Thanks
Old Jun 28, 2018 | 05:35 PM
rvarc's Avatar
rvarc
Ended up having to get a new solenoid pack. $850 !
I suspected that after searching the symptoms. I'm wishing now I had done it myself for around $300 including fluid and filter. I hope this will help someone else in the future.
Recap: I couldn't shift from P or N to D or 2 or engine would shut down. I could shift to R ok and I could shift to 1 and manually shift to 2 and D as I got going. Once in D the transmission would work properly but I had to manually shift to 1 before stopping.
Specifically, the problem was the torque converter clutch solenoid which locks the torque converter together at a certain speed through a clutch (but you have to replace the whole "pack" of solenoids). When it fails it stays in the locked together mode but only in D and 2 for some reason.
Old Jun 28, 2018 | 06:42 PM
  #28
McLeod's Avatar
McLeod
Glad you got it figured out and actually reported back.
Only downside is you are almost 1/2 way to a new transmission
Old Jun 29, 2018 | 09:57 AM
  #29
rvarc's Avatar
rvarc
Yeah, that hurt.
Old Jul 9, 2018 | 05:30 PM
  #30
rvarc's Avatar
rvarc
Update to the update. I jumped the gun by saying that the solenoid pack was the fix. The Aamco guy was convinced that it was the issue and replaced. Fortunately he was more than fair and didn't charge me anything since he hadn't fixed the problem .
After much more researching, I started following the wires from the solenoid pack to the pcm. Low and behold, the previous owner (a ford mechanic) had installed a switch in line with the wire coming from the solenoid pack to the pcm ... and tucked it neatly out of sight. Apparently it hadgotten bumped and was in the on position. Turned it off ... problem solved.
