Puck hitch system
Old Jun 13, 2018 | 08:52 PM
Animalv's Avatar
Animalv
Puck hitch system
i read a thread over a year ago and can't find it the guy put the puck hitch system in a 1999 to 2003 superduty and I want to find out what's involved on the install TIA
Old Jun 17, 2018 | 12:39 PM
RA12726's Avatar
RA12726
Banned
I know you haven't gotten any responses... I just wanted to let you know that I searched both this forum and the web and cannot find anything about installing the puck system on a truck that old (though there are several threads about doing it on newer model trucks). Have you considered contacting a salvage yard? They use nation-wide databases nowadays and can do a search for the parts for you.
Rob
Old Jul 11, 2018 | 02:44 PM
89LX306's Avatar
89LX306
You might check with Pullrite. I had their below bed system for my SuperGlide on my old 2002 F250 years ago. It worked great.
I'm not sure what other hitches it fits.
ISR Series Mounting Kits | Fifth Wheel Hitches by PullRite
Old Jul 11, 2018 | 10:38 PM
jetjockey99's Avatar
jetjockey99
I have the Reese puck system on my '03 dually. It is a slightly different under bed design than the newer Ford OEM system that they also make for Ford. It is multi-piece and bolts together and only took me 45 minutes to install, I used to install a lot of hitches in an other life so I'm fairly good at it. I bent a couple of flanges on the bottom of the box and was able to slide the cross members in without lifting the box. The actual dimensions for the pucks are exactly the same as the OEM and any puck system hitch or accessory works just fine.
ImmortalCrabman
Michigan Chapter
Apr 17, 2019 09:16 PM
Race Red F-250
Sep 19, 2018 11:10 PM
BlueJeansF350
Mar 13, 2018 08:53 PM
Mike Mihlfried
Aug 12, 2017 05:09 PM
Sword
All Things Towing
32
Aug 4, 2017 06:32 PM
