First Restore
Old Jul 1, 2018 | 12:18 PM
  #31
Hotrod350's Avatar
Hotrod350
Originally Posted by neighbor443
A compression test revealed a mix of mostly 60-80psi with two 0's. One of those 0's was resolved with carb cleaner and pb blaster, the other one persisted. So, I took the head off the side with the persistent 0 psi cylinder (driver side rear, I think cyl 8).
What's the best way to clean 'er up and proceed?
Best way? Depends on how badly you want to get it running. Really bad: Wire wheel attached to a drill/grinder. Mint Restoration: Find a machine shop to tank the engine and heads.
Old Jul 1, 2018 | 12:57 PM
  #32
ben73058's Avatar
ben73058
Hey Steve,
(7) out of (8) with compression isn't bad after sitting for a long time. I'd keep soaking it lubing it. Can you tell
if your valves are moving on that cylinder?
Ben in Austin
1950 F1
Old Jul 1, 2018 | 08:46 PM
  #33
neighbor443's Avatar
neighbor443
I took the head off and sure enough the intake valve is stuck open. I'm soaking and cleaning that head. I'll likely remove the pistons to replace rings but I figured I'd replace the valves while I'm at it. I've put together some parts, does this look like it'll cover this partial rebuild?
Old Jul 1, 2018 | 11:42 PM
  #34
3twinridges's Avatar
3twinridges
That’s a cool looking truck. If it were me, and I had water in the oil, a nest in the engine, and stuck valve parts I would break it down and have a shop at least clean it and mag it. These trucks tend to be money pits and if I was going to sink money into it, I would want to know I had a good block to throw money at. And would only want to rebuild it once. Probably the next thing you find once you start it is your water pump seals leak and it just keeps going......
van pelt sales sales is a good place to get engine components. That way if you have any trouble with any of it or have questions Mac can help you over the phone.
my 0.02....JB
Old Jul 2, 2018 | 10:05 AM
  #35
52 Merc's Avatar
52 Merc
And just to be clear, Mac's Auto Parts, (that you're looking at) is not the same as Mac Van Pelt at Van Pelt Sales. VANPELT SALES LLC - your ford flathead source since 2006
Your level of service will be drastically different. It's always good to deal with people who know these trucks and parts, rather than a wage order taker.
Old Jul 4, 2018 | 12:16 PM
  #36
neighbor443
So I decided to clean it and if everything looks ok, put valves and rings on it. Just as an fyi for anyone else coming across this, after trying solvents and dips, the best thing to clean out carbon seems to be heavy duty oven cleaner...works far and away better than anything else I used (including berryman).
Old Jul 4, 2018 | 09:09 PM
  #37
neighbor443
One head nearly done...hopefully I'll be able to pull the cylinders and valves this weekend
Old Jul 4, 2018 | 09:11 PM
  #38
56panelford's Avatar
56panelford
A noticeable difference...
Old Jul 4, 2018 | 09:14 PM
  #39
neighbor443
Is there any significant value in polishing out the combustion chamber while I have it out?
Old Jul 5, 2018 | 07:15 AM
  #40
avf100's Avatar
avf100
​​​​​​​carbon won't build up on a polished surface as much as a non polished one. I used to polished the heads on my 2 stroke motorcycle heads, made a big difference.
Old Jul 5, 2018 | 08:16 AM
  #41
52 Merc's Avatar
52 Merc
Looks good on the outside, but they may still be gunked up on the inside. I think if I were going to this much trouble, I'd drop the heads off at a good, local machine shop, have them hot tanked and surfaced so I know they're clean and the surface is true. My 2c.
Old Jul 5, 2018 | 09:56 AM
  #42
neighbor443
I do plan on filling a container with a CLR dilute and putting these in there for rust removal in the coolant path. I'm hoping that this will be sufficient for my driver-type restore.
Bp77
Jul 17, 2017 10:06 PM
ohbrian
20
Sep 21, 2013 01:42 PM
private-aye-fish
May 31, 2006 03:26 PM
atlantis77
Jan 30, 2004 09:06 PM
Fal Grunt
Sep 27, 2003 05:48 PM
