Sponsored by: Real Truck
Owner
Old Jun 12, 2018 | 07:59 PM
John Boulay's Avatar
John Boulay
Owner
2011 6.7 injector hold downs clamps are defective. TSB
ford has revamped these parts. They break and cause the injector to blow out. Code Po 263 comes up. Get to service garage ASAP when you see this. The engine will shut down. More damage may result. Do all 8 cylinders when this happens. Cost $1300.00.
Old Jun 13, 2018 | 05:27 AM
senix's Avatar
senix
there have been a couple with broken hold downs, not an issue overall through.
I don't see why it would cost 1300 bucks to replace those though.
Old Jun 13, 2018 | 08:17 AM
John Boulay
Mountainman716
sennix
yes $1300 is outrageous but I was told it is the labor charge at a Ford dealer which I assume is the book rate for the hours it takes to do this job.
These I was told failed on 2012 , 2014 year models also. Must be more of an issue if ford has re- engineered the part replacement.
speakerfritz
Mar 25, 2016 01:36 PM
FERdter
Jul 25, 2014 05:12 PM
ImSoAmish
Nov 10, 2009 05:43 AM
4inchlovin
63
Mar 25, 2008 05:14 PM
mbnv992
Jan 31, 2005 03:50 PM
