Bubble cup holder TSB?
Old Jun 11, 2018 | 09:12 PM
Spoojr's Avatar
Spoojr
Hi guys,
I've searched the forum and found many threads on guys having trouble with the cup holder bubbles being pushed in and not returning to normal. I have also seen where some were lucky enough to have the dealer install the "new style" (Job 2 through 2018) where it is a "spring" backed tab instead of the rubber bubbles. I took the truck in to have them replaced, and they replaced the back ones with the new style, but the front ones with the same darn bubbles. (Which quickly were pushed back in again).
Is there a TSB or something where I can get the new style ones? The dealer is telling me there is nothing they can do, as those parts are the ones that are being reported by the Ford system as the replacements, and even giving them the part number to the new style can't be used.
Any advice would be appreciated. I am tempted to immediately make another appointment to have them replaced as I pick up the truck, and simply keep dropping it back off over and over again until they fix it with the new style, considering they keep getting pushed in. Surely Ford will see that the bubbles aren't any good. (Hence the design change)
Old Jun 12, 2018 | 08:43 PM
Spoojr's Avatar
Spoojr
Just one bump to see if anyone has had any luck getting their cup holders replaced recently with the new style. Thanks!
Old Jun 13, 2018 | 03:04 PM
Deadbuck's Avatar
Deadbuck
I complained to my dealer on my 17 lariat and they swapped them for the new style ones. First time I mentioned it they took care of it. My dealer is pretty cool though
Old Jun 13, 2018 | 03:34 PM
Spoojr's Avatar
Spoojr
Thank you. I forwarded this thread to my service advisor so she can see it isn’t unprecedented. Not sure what will come from it. Wish me luck!
Old Jun 13, 2018 | 04:23 PM
System's Avatar
System
Prolocutor
There was never a TSB. Many dealers did it when the change was first made but Ford clamped down and is now telling dealers they must swap the cupholders with the same style that is being removed. There are workarounds for this and after some pressure my dealer found a way. It took some wrangling though.
Old Jun 13, 2018 | 04:29 PM
Nosedive10's Avatar
Nosedive10
My 2018 has the "spring" backed tab, but honestly I don't have much hope for them either. Had those in my Fusion and they lasted a year before the springs broke. I try to keep larger cut that would push them all the way in in the left side cupholders. I am certain that's what broke the ones in my Fusion. Bad design all the way around that Ford needs to come up with a real fix for.
Old Jun 13, 2018 | 07:03 PM
1956Fatfenders's Avatar
1956Fatfenders
Sometimes they try to reinvent the wheel. Never had an problems with the cup holders in my 2012 F-150.
Old Jun 13, 2018 | 09:55 PM
Spoojr's Avatar
Spoojr
Thanks for the replies everyone. I’ll let you know what comes from it.
Ra6hc
Jul 16, 2018 05:56 PM
ruphianh
Apr 25, 2018 08:18 AM
dave91gt
Modular V8 (4.6L, 5.4L)
Feb 26, 2014 01:34 PM
lwk362393
Feb 20, 2014 09:11 AM
RedneckTrucker
6.7L Power Stroke Diesel
May 12, 2011 09:46 PM
