Stuck in high gear
Old Jun 10, 2018 | 11:43 PM
Tony88's Avatar
Tony88
Stuck in high gear
2007 6.0 bullet proof. I got into it a little bit and when she shifted she banged hard in to gear. Seams like she stuck in high gear
Old Jun 11, 2018 | 08:11 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
There should be codes stored to give you a starting point. The places that read codes free CANNOT read these codes. You need either a good independent shop or a Ford dealer.
Old Jun 11, 2018 | 08:40 AM
Tony88's Avatar
Tony88
I for get what code it was tcc so i changed all the solenoids instead of the one now no codes and still seams like she is stuck. She wants to go but only when rpms are 2100
Old Jun 11, 2018 | 09:23 AM
F350 1990's Avatar
F350 1990
These TorqShifts are really quite durable, reliable, but basics first --- check PCM with extended manufacturer codes, harnesses, ground strap, and line pressure @ tap.
Maathiu Ra Yin
Electrical Systems/Wiring
Oct 18, 2016 09:37 AM
jimbo285
Mar 4, 2013 10:40 PM
tonefordays
Feb 27, 2012 02:49 PM
cathlabdog
Oct 25, 2006 07:20 PM
robraz
Oct 26, 2005 10:42 AM
