2011 to 2019 Explorer Discuss the 2011 to 2019 Explorer
2013 3.5 Fwd explorer Jerks at lows speeds !!
Old 06-09-2018, 08:56 PM
Carlobatt85's Avatar
Carlobatt85
Carlobatt85 is offline
Hello guys this my first time here so bare with me...
i have a 2013 explorer a just bought it has 181,000 miles, the truck jerks or hesitate a lot when accelerating at low speeds ( 20mph to 40mph aprox.)
spoke to a couple mechanics they all said change spark plugs and maybe ignition coils too, so i did new coils and Sparkplugs. I tested the coils for resistance and they were all between 0.7 to 0.9 omhs. Problem not fixed yet.
No engine light on so my obd2 i havent been able to get any codes out of it yet.
If i accelerate hard it doesn’t do it.
Any ideas?
thanks for your help.
Carlo B
Old 06-17-2018, 12:12 PM
Aciancio's Avatar
Aciancio
Aciancio is offline
There can be a number of issues that cause this, both electrical and mechanical. Not having driven your to feel it I am kind of guessing but here we go. Have you tried scanning for codes? Not all codes throw the engine light, you may need a higher level scanner to see them. The Explorer is a "drive by wire" system and you could possibly be having issues with the throttle position sensor or accelerator petal sensor. There could be problems with your fuel injectors or fuel filter (seems less likely as hard acceleration doesn't give you problems). This could also be caused by your CV joints/axels being worn or stcicking. If your Explorer is 4WD it runs primarily in front wheel drive in normal mode, during hard acceleration is transfers more power to the rear wheels. Try running in the different modes to see if you notice any difference. And last/ or first, you could disconnect the battery cable for about 30 min to give the system a reboot.
good luck and let us know what you find.
Old 06-17-2018, 12:26 PM
Aciancio's Avatar
Aciancio
Aciancio is offline
I am also a big fan/ believer in seafoam. With that many miles I would seafoam your top end and pour the rest in the gas tank.
If you don't know what I'm talking about just let me know
Old 06-28-2018, 12:53 PM
wiingnut's Avatar
wiingnut
wiingnut is offline
I believe there was a recall on the throttle body, however, I'm not sure if 2013 was included
Old 04-27-2023, 08:51 PM
LivingWild's Avatar
LivingWild
LivingWild is offline
2nd Gear
Explorer "Stutters" at low speeds
Any ideas?
Carlo B
Hi. I had exactly the same issue, with mechanics telling me it could be a million things (all costing a fortune). I then looked online and found a YouTube video ... Transmission Fluid change !!! I couldn't believe it, but put down $175 at Valvoline and the transmission fluid was dirty as can be. It worked !!! My explorer doesn't "stutter" anymore. I was actually looking for that post now (to thank the guy) when I saw your issue (exactly the same as mine). Hope this works for you.
Best regards
Old 04-27-2023, 09:00 PM
LivingWild's Avatar
LivingWild
2nd Gear
This is the YouTube video I was talking about. Take a look ... its going to save you a lot of gray hair.
mrbarnard
02-18-2014 09:18 PM
zdeena
09-27-2007 10:49 AM
screamin
21
12-03-2006 08:09 PM
wickware
06-23-2006 11:21 AM
reberhardt
02-03-2002 09:58 PM
Quick Reply: 2013 3.5 Fwd explorer Jerks at lows speeds !!
