Exp not turning over?
Old Jun 9, 2018 | 05:39 PM
trike1946's Avatar
trike1946
Question Exp not turning over?
Hi, my 99 Expedition has been sitting for about two years and a half. I had told my grandson he could have it because I wasn't using it. I think he never even started it after I took it to him. And he never transferred the title. He said it was too old and wasn't interested. So I was going to get it running and give it to somebody who needs it. I charged the battery. I tried to start it and it does not turn over. Has it been long enough for the engine to seize? Could something like the alternator or power steering be locked up from rust and keep the engine from turning over? Or the belt tensioner?
Old Jun 10, 2018 | 10:12 AM
alloro's Avatar
alloro
By not "turn over", does it do anything, a clunk, a click, a thud, or no noise at all?
Old Jun 10, 2018 | 01:44 PM
trike1946's Avatar
trike1946
It makes a loud noise like a clunk. Louder than a solenoid noise. I was thinking maybe a starter or something frozen? I am doing it myself so I can't try to turn it on and look at the engine at the same time.
Old Jun 12, 2018 | 08:55 AM
2trux's Avatar
2trux
Try rotating the engine with a socket on the crank pulley.
Old Jun 12, 2018 | 12:51 PM
Skauber's Avatar
Skauber
Could be seized engine if water or condensation made its way into the engine. If you suspect the from belt drive, you can just remove the belt and see if it makes a difference, though I doubt it. Try to rotate the engine with a 1/2" breaker bar as suggested, then you'll probably know what is going on.
Old Jun 15, 2018 | 08:31 AM
Jasonmccrory's Avatar
Jasonmccrory
Mine did this
I was given a 99 with the same iaaue. It sat for 3 years. I had clicking from the solenoid on the firewall as well. Mine ended up being the crank sensor wires. Chipmunks chewed them. I put a jumper wire in, twisted em together and it started right up. Good luck
Biggg72
Apr 11, 2015 01:49 AM
Kendrick
May 14, 2011 03:15 PM
dfooch
May 16, 2008 07:30 PM
VaSheriff
Sep 26, 2006 10:01 PM
RH F-350
1997 - 2003 F150
Jan 18, 2006 09:13 PM
